In the processing of finishing my installation of a storage box on my T@B. This turned out to be a lot of work but I think it was worth it. I looked at a lot of installations but never saw one that I like, so I came up with the idea to store my portable solar panel behind the storage box in two rails bolted to the back of the box and split the original T@B plastic box in half and install on each side to house the battery and propane tank. Spare tire mounts on the jack but not shown in the attached picture.
Huntington LI
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
I made a padded thick cover for the solar panel and I can store it either way. If I store it with the panel facing the tow vehicle, the only part of the solar panel that is not completed protected by the aluminum box is the very top that is about 3 inches higher than the top of the aluminum box. The rest of the panel is completely protected by the back side of the aluminum box.
https://smile.amazon.com/Buyers-Products-1705420-Aluminum-18X24X36/dp/B01ASXUDLO/
Cool idea.
PNW
It was quite a bit of work to figure out how to mount the box using a single aluminum I-beam I had on hand.
I cut like this:
Then cut to slid over the trailer frame as shown in these pics:
Note above the two pieces of unistrut used in front of aluminum I-beam to support the front of the battery and propane frames and the very front of the plastic tub where it joins to the new aluminum box.
Above you can see an aluminum late used to join the two I-beam sections together and the cut out required to slide each I-beam section over the trailer frame. I used only the original holes in the trailer frame in mounting the box in my modification.
I had to be very careful splitting the original TaB plastic box/original angle iron frame since there was no room for error; one mistake on the plastic tub and things would have gone south. I did some minor additional bracing on the original angle frame since it was allowing enough movement mine developed some cracks in the base flat iron and the plastic tub had a few cracks at the bottom attachment points. Basically I added a extra brace on the vertical angle iron members. I repaired the plastic tub cracks using a soldering iron and carefully melting the crack closed which worked good (repaired crack cracks can be seen in second picture above.
Propane tank retaining ring is the original with modifications to re position it on the base and I inserted a piece of plastic cutting board as the base for the tank. I removed the original powder coating from the frame which already had severe disbondment and was rusting in many places. Where powder coating was good, it was very difficult to remove. Appears they do not do a good job of prep before powder coating.
It took a bit of figuring to recreated a hinge point for each half door on the original tub where the top was cut in half but it came out very good in my opinion - no pics of this at the moment.
Hope the above provides some idea as to how I mounted the boxes. You could use other materials and methods to mount, but I used materials I had on hand that I knew would be strong even if a bit of overkill using the large aluminum I-beam. There was a lot of figuring and measuring to make sure everything fit up like I wanted it to (to look like a factory job).
