On a short trip 70 miles from home, at a gas station after a long down grade I had 115 F on the driver's side wheel, 180 F on the right.
Emergency pin not pulled; no skidding or anything. Just real hot and excess brake dust on the wheel hub. Wow.
Fortunately the place I bought it is on the 2-hour trip home. We're camping by the New River for three nights and this is putting a real damper on things.
Any thoughts or suggestions?
                - Virginia
- 2020 T@B 400
- 2018 Tacoma SR V6 3.5L
0 ·
How are you measuring your drum temps?
2019 320 Boondock Edge - Sold Jan 2022
Brake controller being out of adjustment won't cause uneven temps, I doubt that is your issue.
Yes I noticed the discrepancy after a long downhill in blue ridge mountains. But I always downshift and never ride the brakes.
Also, heard a scrape srcraaape scraaaaape sound from that side when braking after that.
Very much appreciate this input!
Jack up the trailer using the correct jacking points.
Position your jack stands so that they do not interfere with your access to the back of the brake drum.
Locate and remove the access plug cover.
Spin the wheel slowly. All you are trying to do is feel/hear the brakes rubbing inside the hub.
With the brake adjusting tool you will reach into the hub opening and make a few turns on the adjuster wheel to tighten the brakes. The objective is to get the brakes to drag very slightly and not enough to keep the wheel from turning. You will try to get both sides to about the same adjustment. Turn the wheel while you adjust to make sure of the results. Adjust to the tightest spot on the drum.
On a scale of 1 to 5 with five being a super technical job requiring special tools and skills, adjusting the brakes is about a 1.5...you can and should do it.
Here is a related recent thread with a video that shows the process.
https://tab-rv.vanillacommunity.com/discussion/comment/140488#Comment_140488
Do not use a screw driver as shown the video. A screw driver can damage the soft metal adjuster nut.
I think that is correct for the T@B.
In the original post Warbler_Road was talking about running a long downhill grade. From the available information, I assumed they were braking during most of the run when I attempted to make a diagnosis online (in a later post they noted that had not been using the brakes much).
I agree that under normal driving conditions, with little braking, that 115 degrees is reasonable on drum brakes.
@CrabTab , note that there were scraping noises heard from one side. The temperature is not the red flag.
What's the mileage for a repack job? I doubt we're close to that yet though.
Safely home now with no issues, and I already bought some jack stands to do the adjustment. And it turns out the scraping sound was coming from the rear drum brake of my Tacoma! :-/ Sigh.
Thanks again for all your help.
Then I did the brake adjustment per the same manual
So I can see why some would not want to fool with this procedure just to save 100-150 bucks. In fact if done wrong you can create a dangerous situation like a wheel coming off... So just be aware of the risks.
Not sure I know when to use the EZ lube system. It seems to take a lot of grease per wheel and also creates a lot of pressure to force the grease from the zerk to the inner bearing and then back forward to the outer bearing. Unless you are 100% sure of your rear seal, you could force grease into the drum and basically ruin the assembly. Plus you are not actually looking at your bearings and races, so you can't be sure they have not sustained damage. Anyone else know the rationale for EZ lube?
Thanks
I think I just had a passenger-side brake that was too tight and taking most of the braking load, and want to correct that. Tackle it tomorrow ...
I determined that brake "hum" was NOT coming from the cool (left) side when the manual override on the tekonsha was pressed.
Eureka! Electrical problem.
So I took off both hubs just to look at them. The hot (right) one was blackened and dirty inside, as if it had been doing all the braking. Other side was much cleaner, but with some pink grease splatter inside. Interestingly, the lower clip securing the magnet wires to the actuator arm had come off. When I put it back on, I got brake hum again when pressing the override on the tekonsha. Perhaps it had been flapping loose and the wires inside had frayed? Putting it back had put the frayed wires back into contact? Not exactly "fixed" ...
Adjusted again, took another 3-mile test drive and the right is still hotter, but not as much. Gonna back off a few more clicks on the adjuster wheel on that side and try it again when it cools.
All this on a quite expensive camper, my first, with 1300 miles on it.
Just weird. My dealer and every nearby trailer place has a 30-day backlog because of The Virus.
Thoughts welcome.
Left (cool) side):
Right (hot) side:
Mis placed wire is also concerning. Hope someone can advise as I do not have those skills.
How did the bearing seal look? Since you have a 2020 400 model, you may want to have it checked under warranty. There definitely should not be grease on the brake magnet. To me, it looks like someone either re-packed the bearings using the EZ-lube and maybe exerted too much pressure, possibly damaging the seal, or put too much grease on the spindle. You also should be sure that the electrical connection is fixed.
Have you tried a small trailer sales/repair shop to have everything checked out? Not an RV repair shop, but a company that sells and repairs small flatbed trailers? Regardless, you should make nuCamp aware of the issue and send them photos. See what they say about a warranty repair.
Here's another image of the opened hub, unfortunately slightly blurry, showing the amount of grease.
I definitely plan to make a warranty claim and have already contacted NuCamp. I also have a good small trailer place right up the road, but they said they are swamped for the next month because of COVID. My dealer's farther away and even worse off.
Left (cool) side:
None of this should be necessary with so few miles but here is the text book example of the problem with the Dexter hub. If someone gets carried away with the grease gun this is exactly what happens. If you did not do this then the dealership did...warranty repair is their obligation.
The other wheel is probably still only in need of a bit of adjustment but who knows. After seeing this it also should be taken apart. Good luck. What a pity to have to deal with this on a new rig.
Will keep you posted.
They were of the opinion that extra grease had been added via the EZ Lube fitting without spinning the wheel, causing it to go out the back seal.
So far so good, and kudos to Dexter.
Will keep y'all posted.
