Hi
I have a new 2020 Tab 400 with the Alde 3020.  When I turn on hot water at either sink it takes a while for the water to get warm but then it goes back to cold after only a few seconds.
Alde shows water temp is 117 degrees and is running off shore power (15 amp connection to house). Bypass is in normal position. All valves are in the correct position. Mixing valve is set to max. Hot water hose feeding into the mixing valve is warm to touch.
What am I missing?
Thanks.
                2020 T@b 400, Build Date 10/2019
Norcold 3-Way Refrigerator, Factory Victron Solar
2019 Honda Ridgeline
0 ·
https://tab-rv.vanillacommunity.com/discussion/5018/no-hot-water-at-kitchen-sink-bathroom-sink-had-hot-water#latest
If the Alde pump is set to Continuous ("Cont.") circulation (as opposed to Thermostat ("Therm") driven), you cannot choose the partially shaded icon. In the Continuous pump mode, you can choose the “Boost” (fully shaded icon), which stops the glycol circulation for 30 minutes and allows the water to get extra hot for showering. So, if you keep the pump setting in the Therm mode, you can adjust your water temperature to partial shade AND use the Boost.
“BOOST” MODE: When you set the shaded area at full, the “central heating” of the cabin is turned off and the glycol pump will stop circulating (thus not heating the camper cabin) for approximately 30 minutes. This focuses the heating on the water tank so that the water can be super-heated. After that, the system will revert back to the normal cabin heating/circulation mode. It is only when you want extra hot water, such as when you want to take a hot shower, that you may want to use the “boost” setting, as indicated by a fully-shaded hot water symbol. “Boost” can be used on either electric or propane, but the Alde is more efficient when operated on propane.
CENTRAL HEATING PLUS HOT WATER: If you have the temperature set so that you are heating the cabin, plus have ½ of the shaded icon filled, you will have BOTH cabin heat and hot water at the normal setting (approximately 120-125 degrees.) Normally, you will leave the shaded symbol half-filled. However, if you are not in need of hot water, leave the shower water icon empty and the water will only be heated to a “warm” temperature.
I fixed my hot water supply issues this way as well.
Please be careful though, because my hot water is now VERY hot...which is what I wanted so I could mix the relatively small volume of hot water with cold and have plenty of warm water for a shower...but it feels hot enough to scald I think...So please just be super careful to understand just how hot it is. Especially if you're using the hot water "boost" feature.
And to add a small anecdote...I'm currently camping in the Blue Ridge mountains and staying at a full hookup site. After hiking for 6 hours this morning I just had a wonderful long hot shower - plenty of hot water once you adjust the mixing valve.
The water source (cold) is connected to the Flow tank, then the hot water output is feed to the former cold water input on the Alde main unit. The glycol goes from the Main Alde heater to the Flo, than to the floor heaters. Next you need to add another overflow drain for the Flo tank.
Here is a complete factory install, the Red tank is the Flo aux water tank.:
