JENSEN JWM20 Cube Wall Mount Stereo
An external hard drive needs to be connected to a computer first, most radio/dvd players do not have the ability to stream off a hard drive directly.Cheere2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
I found some info. on hooking up my roku via a 12v cable and using my phone as a hotspot for the roku.Denny16 said:An external hard drive needs to be connected to a computer first, most radio/dvd players do not have the ability to stream off a hard drive directly.Cheere
My roku has a usb port on the side which i can plug in my hard drive and play the movies using the roku media app. should work. Here is the cable link: https://www.amazon.com/Cable-Powering-Roku-Eliminates-Adapter/dp/B014QC1RFE0 -
Thanks for the added details. The Roku is the host computer with software to stream the hard drive media. I was referring to connecting a hard drive directly to a Jensen radio/TV.2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
Found a mini-DVD player that fits into the open slot and plays on the Jensen television and gets sound (trifecta) ! 4 year old Granddaughter has every Disney DVD known to mankind and has had three sleepovers with us so far and calls our T@b her “movie theater”!
Cost $45 on amazon, and I had to buy a micro USB connector. Says it won’t play blue-Ray, so not perfect. Setup was two minutes and pic quality is good. Will disconnect and box up when we are traveling, as I can’t attest to its durability Amazon Celhoit brand, search mini DVD player hdmi2021 320 S Boondock / 2018 Toyota 4Runner / NE Ohio0 -
Has anyone with the JWM20 Cube been able to confirm if while watching TV over antenna/cable if the sound comes out of the stereo speakers? I think this would be possible if the Cube is on "Aux" but would like someone out in the wild to confirm as my Tab 400 is still on order.Update: This is confirmed here: https://tab-rv.vanillacommunity.com/discussion/11879/jensen-jwm20-cube-television-audio#latest2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO0
I have solved Bluetooth hangups by using the paper-clip reset. Shouldn't have to do it so often, but it usually works.0
If one loads a movie on a USB stick, would that play through the cube to the TV?0
