JENSEN JWM20 Cube Wall Mount Stereo
2»
  • Denny16
    Denny16 Member Posts: 5,430
    edited August 2020
    An external hard drive needs to be connected to a computer first, most radio/dvd players do not have the ability to stream off a hard drive directly.
    Cheere
  • EricinMi
    EricinMi Member Posts: 4
    Cheere
    I found some info. on hooking up my roku via a 12v cable and using my phone as a hotspot for the roku.
    My roku has a usb port on the side which i can plug in my hard drive and play the movies using the roku media app. should work. Here is the cable link: https://www.amazon.com/Cable-Powering-Roku-Eliminates-Adapter/dp/B014QC1RFE
  • Denny16
    edited August 2020
    Thanks for the added details.  The Roku is the host computer with software to stream the hard drive media.  I was referring to connecting a hard drive directly to a Jensen radio/TV.
  • mrdeepfryguy
    mrdeepfryguy Member Posts: 73
    edited August 2020
    Found a mini-DVD player that fits into the open slot and plays on the Jensen television and gets sound (trifecta) ! 4 year old Granddaughter has every Disney DVD known to mankind and has had three sleepovers with us so far and calls our T@b her “movie theater”!
    Cost $45 on amazon, and I had to buy a micro USB connector. Says it won’t play blue-Ray, so not perfect. Setup was two minutes and pic quality is good. Will disconnect and box up when we are traveling, as I can’t attest to its durability Amazon Celhoit brand, search mini DVD player hdmi
    2021 320 S Boondock / 2018 Toyota 4Runner / NE Ohio
  • rhyno
    rhyno Member Posts: 393
    edited November 2020
    Has anyone with the JWM20 Cube been able to confirm if while watching TV over antenna/cable if the sound comes out of the stereo speakers? I think this would be possible if the Cube is on "Aux" but would like someone out in the wild to confirm as my Tab 400 is still on order.
  • BywaysNW
    BywaysNW Member Posts: 71
    I have solved Bluetooth hangups by using the paper-clip reset. Shouldn't have to do it so often, but it usually works.
  • Oneota
    Oneota Member Posts: 18
    If one loads a movie on a USB stick, would that play through the cube to the TV?
  • ontheroad
    ontheroad Member Posts: 489
    @oneta..download the jensen manual..if it's a 2021 google "jwm22"...sorry can't provide the link...great resource
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
