https://alpgenerators.com/ Saw this propane-powered generator advertised on the OverlandExpo site. (They are offering a $50 discount during the virtual expo, bringing the price to $450.). Looks like a 1000 Watt output, and seems to provide for parallel syncing, though I don’t see a parallel kit on their website. Assuming it were a reliable unit, it would make for a quiet, clean boondocking generator for charging your battery system or running small appliances.
https://www.amazon.com/Baja-900-Watt-Propane-Inverter-Generator/dp/B083VS1N2M/ref=sr_1_6?dchild=1&keywords=propane+generator&qid=1596807161&sr=8-6
The ALP looks interesting (and yay, color choices!), but I don’t like that they’re claiming it’s quieter than the competition without providing actual numbers or details on who they’re comparing themselves to. That sort of marketing throws red flags for me—it doesn’t mean the product is necessarily bad or deceptive, but it does mean I’d be digging a whole lot deeper into independent reviews to confirm their claims before buying.
Also annoying that at that price, they don’t include a hose for use with a 20 lb tank.
It sure would be tempting just to use the 12V output of the ALP and wire that directly to the battery bank. But in the ALP operating manual it says the peak DC current is only 6.3A. Seems a bit low when the inverter is pulling 50A when running the A/C. I'll have to see if there's another brand like the Ryobi or Baja that can at least produce as much DC current as the stock converter. Guess I can just use an AC plugin smart battery charger I always carry anyway to connect to the battery bank and run it in 12A mode, but it seems wasteful to do an extra conversion. Or is it extra? Not sure how the electrical innards of a gen/inv creates energy... DC first, inverted to AC... or straight to AC somehow.
And yes, one does wonder how far away that was.
@DougH I have a pair of Yamaha 2k gens at home, after a week long power outage in winter one year. They’re great insurance, haven’t had an outage like that since! They’re heavy, bulky, and I didn’t want to carry all that gas traveling (which has to be properly treated and stored or it gums everything up). I’ll never have a gas-only generator again now that I've discovered propane.
All I wanted was a way to charge the trailer battery when solar wasn’t enough. The Ryobi propane genny takes 1 pounders, which I already keep stocked for use in emergencies with my Big Buddy propane heater, or it can be run off a 20 lb tank with the included hose. Weighs just 25 lbs. If I were in the market now, I’d definitely consider going with the ALP, which is a tiny bit more powerful and theoretically quieter.
Whether or not either the Baja/Ryobi or the ALP will run the Danby is questionable, I haven’t tried. The first question in the Q&A on the Home Depot page for the Ryobi shows mixed answers...depends on the draw of the A/C at startup. I’d say measure that first. https://www.homedepot.com/p/RYOBI-900-Starting-Watt-Propane-Powered-Inverter-Generator-RYi911LP/302703564
Generators produce AC current directly via the motor turning an alternator - but inverter generators rectify the AC to DC, then invert it back to clean, unvarying AC current.
Here's a decent layman's explanation - but I'm sure there are many others as well:
https://www.norwall.com/power-expert/generators-and-inverters-whats-the-difference/
https://www.cabelas.com/shop/en/champion-2000w-dual-fuel-inverter-generator
It is dual fuel, 2000W on gas, 1600W on propane, rated @ 53DB, comes with a propane hose and can be linked in parallel (should you want to go all out on electricity in your 400).
https://www.cabelas.com/shop/en/champion-power-equipment-30-amp-paralink-parallel-kit?rrec=true
We have the gas version. It has worked well, when needed. The weight isn't too bad at about 47LBS.
This may or may not meet your needs...
2019 320 Boondock Edge - Sold Jan 2022
@ChrisFix ; Sound like from your post and the article's details, they ought to be able to produce a lot more DC current. But maybe some brands can. Or maybe the DC coming out of the rectifier is too choppy with the same motor frequency noise in it, and is considered unsuitable for DC outlet use... so a separate module produces a cleaner DC output but at only 100 available watts instead of 1000. Thanks for the explanation.
I did find a 9000W wind turbine system on AliExpress for only $150. Sure, that's been a failed experiment for every RVer who has ever tried one in typical 3-5mph wind conditions... but they couldn't advertise it at 9000W if it wasn't true.
And most of the gas or propane generators are measuring decibels at 20 feet instead of 1 meter. Pointless, except as a comparison between models all tested at 3/4 load.
Is the Ryobi as quiet as the Honda?
Edit: ah, now I see your previous post re trying to reduce your fuel containers.... Propane's tidier too.
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
2020 Subaru Ascent
28 lbs is very enticing.
Jeff & Amy
Still, a quality efficient generator for those in need. Video shows it could run a 550W A/C for 20h (with A/C compressor always running) off a typical tank. Maybe a week of more typical air conditioning with two 20lb tanks. Video also shows perfect sine wave regulated 14.1v output for using to charge a battery bank if solar isn't available.
Hobotech's sound test was done with the meter closer to the unit (3' away) than others I have seen. The LOLOHO guy does it from 25' in his reviews and says it is an industry standard?
I usually won't be 3' feet away from the generator when its running, and if my camping neighbor is that close, we will be having a different discussion. LOL
Jeff & Amy
Sold 2023 Tab 400
Sold 2018 T@B 320S
Haven’t watched the ALP video yet, and that decibel measurement REALLY needs to be retaken at the correct distance (and after engine break in, if that wasn’t already done.)
The review says it's durable, but I'd like to hear some real user experience
