What is the little green light switch above refrigerator on the left side? I think the dealer said it was a fan to keep things cool? If so, should this always be turned on if the refrigerator is running? There is no mention of this switch in the Norcold literature.
0 ·
San Diego, CA
www.airbossone.com
camping trip work 2nd trip did not work
i checked the fuse box but without success
San Diego, CA
www.airbossone.com
The three way has a green light on the right that lights when the propane is in use.
our indicator light is located above the refrigerator to the left of the Jensen radio/DVD’s player
i do need to check if the fan turns on when the switch
is on. I will try this evening
thanks everyone
If you're adventurous, pull the switch out of the wall. With shore power disconnected and battery switch off, disconnect the wire leads on the switch and tie them together without the switch. Turn the battery switch back on and turn on the fridge to 12V. If the fan cycles on (watch your Victron app or the volt meter), it's likely a faulty switch. If the fan doesn't cycle on, it's likely an issue with the fan and/or fridge.
San Diego, CA
www.airbossone.com
Another alternative:
