My unit still in production. Can someone point me to a reference that has the technical details of the battery, electrical and solar system, to include capability, make and model of the components?  Consulting with a local technician on the right mods for my needs, so hoping to find something  useful to communicate the starting point.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
New Mexico
2021 T@B 320s (“T@Bañita”)
2023 T@B 400 Boondock (“Redwing”)
2020 Subaru Ascent (“Bubbles”)
managed by VE Smart Network
Ontario, Canada
"We don’t have any schematics available at this time. but I will try to list some of the electrical components.
Solar Controller – Victron Smart Solar Controller 75/10 https://www.victronenergy.com/solar-charge-controllers/smartsolar-mppt-75-10-75-15-100-15-100-20
Converter – WFCO 8700 series https://wfcoelectronics.com/product/wf-8735-35-amp/
Solar Panel – 105Watt Sunflare Flexible solar panel
That’s really all I can think of that you’ll need when – if there other electrical components that you need info on please let me know "
Ontario, Canada
So why is the Air8 almost twice the power requirement?
It does a lot better job. The window units never pulled out that much moisture and the Air8 does a great job dehumidifying. Also, it would take more power to blow air through the ducts.
Some of the window A/C units have a dry mode, but I've never been able to find any specs on how many gallons a day they can take out of the air. The southern coast states would almost be livable in summer if HVACs could just keep the humidity at 45%. We just sprung for a brand new SEER 17 two stage variable speed heat pump for the stix-n-brix (old unit croaked). When it's above 100F, we're lucky to keep the internal humidity at 65%. Yuck. Our installer said the unit could only pull out 6-8 gallons a day for an average size house. Sounds like, for its size, the Air8 dehumidifies much better.
