I want to sanitize my fresh water system and would like to know if anyone has done this with the Nautilus system.
The main question I have is that the valve settings for Sanitize seem to leave the hot water system open - even though Creed stated that this was the setting to use. (In re-reading Creed's email to me - he says to use the Winterization mode to sanitize - which will bypass the water heater (and is the only mode with the Red valve in the "sideways" position that bypasses the water heater.)
Reading the Nautilus User Manual, it says the Red valve "Sideways - water goes to hot water fixtures without going through hot water heater" and "Up – water goes to hot water heater"...but the Sanitize position is UP, which seems wrong.
Sanitize, Dry Camping, and PowerFill all leave the Red valve "Up"...which is water to the hot water heater...
Also, after siphoning in the bleach solution, can I then "powerfill" the fresh water tank to fill it and set it to "dry camping" and use the pump to flush the faucets - all with the hot water heater bypassed?
The key to all my questions is that there doesn't seem to be an hot water bypass as on prior years, expect the Red valve which seems to be in the wrong position per the user manual.
0 ·
Then fill your water tank as usual, run The solution shortly your system by using the water pump to flush water through the pipes, turning on cold water facets in galley and washroom, run water through the shower.
Let it sit for at leas four hours, or even better overnight.
There is no Alde Bypass valve in the Nautilus water center compartment...Just the hot and cold low point drains, and the 4 Nautilus control valves...
When I talk about the Red valve, I'm referring to the Nautilus Red lever...as defined in the Nautilus User Manual - but again, there is no separate bypass valve for the hot water heater with the Nautilus system on a T@B 400.
But in re-reading Creed's response to me, I see he says you have to use the Winterization mode to bypass the hot water heater...I just substituted Sanitize mode when I read this, as that naturally seems the correct one - and the fact the User Manual he provided only mentions sanitizing via the Sanitize mode.
Honestly, an actual bypass valve would be helpful and probably prevent a lot of people doing this wrong with the Alde.
From Creed today: "Correct – you want to bypass the Alde. The winterization mode in the Nautilus will do that. Place the nautilus in winterization mode to just sanitize. And then move back to the mode you will be using whether it be city water or dry camping."
(Bolded per Sharon_is_Sam - see discussion below for a better way to sanitize the 400 per ChrisFix.)
If there is one, it would be under the driver's side bed platform with all the Alde kit and plumbing. It's a minor pain to get into that, especially with the bed topper, but I'll take a look later.
I do know the Alde low point drains are located there...
For the tank to be siphon filled, the Blue valve needs to be in the down position.
I think the correct answer is for the:
White valve = Sideways (water goes to pump inlet)
Blue valve = Down (water will go to or come from fresh water tank)
Green valve = Sideways (water will not flow through valve)
Red valve = Sideways (water goes to hot water fixtures without going through hot water heater)
This is not a configuration identified by Nautilus - but I think might work? It is the "Sanitize" configuration with the Red valve set to bypass the hot water heater.
Thoughts?
” RED HANDLE: Receives water from cold water supply line
So Red handle sideways, the Alde water heater is bypassed, so add bleach solution with the handle sideways. After sanitizing and freshwater flush, return the Red handle back to vertical to add water back in the Alde hot water heating system, which is the main Alde heater and Flo aux water heater setup.
Yeah, I think the "Sanitize" configuration with the Red valve in the bypass position is the way to go...
Wouldn't of thought this would require so much thinking however!
Yes, one can figure it out...but clearly printed on the Nautilus panel is how to set the valves to Sanitize...and it is going to damage the Alde water heater if you follow the clearly illustrated instructions right on the panel.
It's potentially a significant issue that 2021 T@B 400 owners need to be aware of - and won't unless they spend quality time on this forum.
There is no configuration given by Nautilus that both sanitizes the tank - in addition to the lines - and bypasses the hot water heater, and the one configuration that I'd be willing to bet most people will follow is the one labeled "Sanitize"...which is wrong.
I will take some photos and open up the Alde compartment to verify if there is a secondary bypass valve there as well.
This would be helpful to others to have well documented particularly in that the 320 and 400 are set up differently despite both being "Nautilus" systems.
Paul the AirForce guy did a video on the Nautilus system, and also got this wrong, he followed the Nautilus manual. He also shows Alde and rear of the Nautilus panel, points out the yellow overflow valves, and water pump, and Alde mixing valve. You can see their is not an additional Alde bypass vale under there.
The winterizing procedure used for sanitizing will not sanitize the fresh water tank as is conventionally done...it will sanitize just the lines.
That's the only issue I see with following that advice as given by NuCamp.
https://tab-rv.vanillacommunity.com/discussion/10932/sanitizing-de-winterize-2021-t-b-320s
I had not seen that...
The key difference of course is the 320 actually has a separate and labeled Alde bypass valve.
I think we've proven the Red handle in the 400's Nautilus is actually this same function - just not described or labeled in any way.
The Green handle allows the pump to pump from the tank...not to the tank.
In the Up position, the pump draws water from the tank.
In the Sideways position, no water flows through the valve.
It is only used for "Dry Camping"...when you want to pump water from your fresh tank to the fixtures.
Maybe the direction of flow is dependent on the other valve settings?
Water will not go to the tank with the Green handle in the UP position...it must be Sideways in order for the pump to draw water into the tank.
Never mind. Just raised the bucket up to give the pump a gravity assist. That did it!
https://tab-rv.vanillacommunity.com/discussion/comment/170221#Comment_170221
