We're picking up our very first RV in a couple of weeks and I have an Escape SE with 3500 lbs of towing capability, but i'm having a hitch and 4-pin harness installed. What type of 7-pin to 4-pin adapter will work? I realize it won't work the brakes and i've read it won't be charging my battery while driving, but is there anything else to look out for?
0 ·
Tampa FL
I’m going to pile on here though, any time you use a marginal tow vehicle—at 3500 lbs, yes, the Escape meets the minimum requirements, which makes it adequate, not ideal—and you’re towing more than 50% of your limit, you really should add in the extra safety level of trailer brakes even if they aren’t legally required. With the wireless options available now, there’s really no reason not to do this, as using trailer brakes protects both your vehicle and your expensive new trailer.
Additionally, the Escape owners manual states flat out that trailer brakes are required when towing more than 1500 lbs.
