This procedure seems to be required so often that I have all but quit trying to use the stereo via BT, esp. since all Alde settings get wiped every time you cycle the battery switch on/off. Contacted Jensen customer support, they were basically zero help (i.e. "cycle the power on/off to fix the problem"). I now just use my JBL Extreme, which sounds better and is likely more efficient, power-wise.Bayliss said:@NoVaGuy, try disconnecting the shore power and battery (shut off with disconnect switch.) Leaving the power disconnected for at least a couple minutes. Then, go through the pairing process again. Can't guarantee it will fix the issue, but sometimes a hard re-boot does wonders.
My Jensen problem is that it won’t pair, doesn’t sense the I-phone on BT at all.JeffroNC said:I used to futz with this each time I wanted to play music from my phone through the Jensen. My Iphone was paired and it showed on the Jensen screen but would not work. My solution I used on my phone had been to forget the Jensen and re-pair it.
I read the manual (LOL) and tried the procedure on page 16, selecting my phone and pressing the Pause/Play button on the Jensen to play music. This has been working for a few weeks. I have a toggle switch installed in the TV/Radio fuse circuit and have turned the system off several times. Bluetooth remembers my phone even when it is off. YMMV
I think there's a way, but I don't know that it's a good way.Retriever said:I just replaced my old Jensen unit from a 2014 t@b 320 with a new JWM62A that has Bluetooth. I can BT into the unit from my phone, but want to have an external speaker to play the unit radio/CD out to. ASA electronics tells me this unit does not do that which is pretty disappointing. Has anyone found a good way to wirelessly get music from the RV unit to an external speaker? I've seen BT adaptor but don't know if that would sole the issue.
