I did do a search first and couldn’t find this question. I apologize if it was somewhere and I missed it. have a 2020 Subaru Ascent that has a smaller “temporary” spare tire designed to get you to a repair facility. It is mounted under the car with a mechanical lift. There is not enough room for me to replace it with a full size tire. If my TV has a flat and I am using the smaller spare willI I still be able to tow safely? Sorry if this is a rookie question but my understanding of all things related to towing is slim (but increasing everyday) and I want to be as safe as possible.
Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
0 ·
Your best bet would be to consider subscribing to a tow service that includes towing coverage for your T@B (e.g., AAA, Good Sam, your auto insurance provider, etc.) If you search this forum, there have been discussions in the past about available options, but you will want to confirm that it covers both your tow vehicle and trailer. Otherwise, you will need to leave the trailer on the side of the highway while you are getting your tow vehicle flat repaired/replaced. The only exception in my mind is that you might be able to get away with it if you only have to travel a very short distance (e.g., to get the trailer off the highway and to a safer location, or if a tire shop is close by.) BUT, if you choose to do that, you will need to drive at a low speed (25-30 mph?), which you are supposed to do on an emergency spare anyway.
Here's the post (from an RV forum):
“If you do not have a full size spare and instead a “donut” emergency spare (smaller), then you should not be towing any trailer. This emergency spare can not handle the additional stress of towing. So, you would have to leave your trailer on the roadside if you did get a flat on your tow vehicle and have to use the donut spare.”
2020 Subaru Ascent
Never tow a trailer when the temporary spare tire is used. The temporary spare tire is not designed to sustain the towing load. Use of the temporary spare tire when towing can result in failure of the spare tire and/or less stability of the vehicle and may lead to an accident.
2020 Subaru Ascent
“Also, be careful if you have all-wheel-drive . . . . in some cases, it could cause extensive damage if you use a tire that is a different diameter than the others. Make sure your spare matches, whether it is a "donut" or full-size.”
I didn't include it primarily because a "donut" spare is smaller (at least that has always been my experience), despite it being sized to work with the particular vehicle. If a vehicle includes a "tow package," then it should include a full-size spare (although it may be the stock spare, as opposed to an upgraded tire and/or wheel size, which is common with newly-purchased vehicles.)
Whatever any RV owner on this forum does, always err on the safe side. If it isn't a hazard to other drivers, and you don't have a tow service, it's best to just leave the trailer alongside the highway. Hopefully, you won't be away from it for long and you can secure it with a locking device to deter theft.
2020 Subaru Ascent
2020 Subaru Ascent
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
