Hi everyone.
I recently ordered a 2021 TAB 400 after selling a 2004 Roadtrek. That makes me a first-time trailer owner, and I'm a bit nervous about a few things. That said, I feel I will be able to get proficient at trailering and backing with a little experience. Check.
The thing that's starting to scare me more is the range of technical and mechanical challenges that folks are writing about on this forum. I had my Roadtrek for five years and handled lots of issues regarding refrigeration, plumbing, comfort, sleeping, etc., as well as plenty of engine work. But I had been hoping I wouldn't have to go through the maze of similar issues with a new TAB.
I realize that most of what folks write about is the result of things that go wrong. For example, if you search for the word "leaks" on this forum, you'll get an eyeful of different kinds of problems. The same applies for electrical issues. It's the nature of the beast.
In hope of easing my mind, I'd love to hear from people who aren't having problems with their new rigs. I'm old enough to know that "stuff happens," but still, it can be a bit overwhelming.
If you can pass along some reassuring stories, that would be most welcome.
James
PS I continue to be impressed with what I'm seeing about nuCamp customer service, so no worries there. That's actually quite a relief to an old guy like me.
2021 TAB 400 BDL
No towing vehicle currently owned, looking at F150
Chapel Hill, North Carolina
0 ·
The Nautlius system streamlines the winterizing process after you learn the theory. Learning the "scoop" before backing is half the battle, visualizing the camper going in a straight line while backing to the intended parking spot is the second half. Check! You will love your new 400!
And yes, it’s an online forum. You’re going to see a lot of problems brought up here by people seeking help. You’re also going to see a very high number of modifications here, because this place is absolutely stuffed full of tinkerers. The “problems” they are fixing may not be problems for you at all.
For what it’s worth, look around here and you’ll see a LOT of repeat owners who upsized (and even downsized) within nüCamp’s product line. You don’t often see that kind of owner loyalty in this industry, and for good reason, because many RV manufacturers nowadays build fairly shoddy products.
Personally, I went with nüCamp and with a new trailer rather than used for pretty much the same reasons you did, and I’ve mostly had a positive experience in doing so. Perfect? No. But not a single warranty issue, which means it was a pretty well-built trailer right off the line. I upgraded a few things, and am still fine tuning a few others, and of course, there are areas that *I* think could use improvement...that’s the nature of being human. 😁 But overall, I still recommend nüCamp as one of only two brands of trailer I think are worth the money.
Count me as an example of having no issues with our 2019 T@B 400 since we got it and have had many happy miles learning and enjoying it. Just take time to read the manual and the unofficial resource guide (attached).
Rich
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry
Having those 2 weeks of no pressure and trying new things out every other night or so and sleeping in it a few times really helped the first trip go mostly smoothly. Thus far, what seemed initially like NuCamp issues were simply learning curve. From the Alde mixing valve and the various fuses and what each of the drain valves do ... all acclimatizing and learning the ropes and nothing to do with faults. In fact, the only real fault I had was the stovetop lid not opening all the way and that's a fault of a supplier.
I haven’t spent any time on towing vehicles yet. I was thinking Toyota or Ford, mostly because the two dealerships are about five minutes from my house and other dealerships are quite a long ways away.
My gearhead friend told me that a six cylinder engine might be better than a four cylinder engine, and of the two makes, only Toyota has that six-cylinder option. I don’t really want to step up to a big truck. Would appreciate any advice you have.
Full disclosure. I have never towed anything whatsoever. Never.
Those Tacomas are very expensive. Definitely do some massive research before you buy one. I just saw a discussion that said they were not comfortable. I would strongly advise against any 4 cylinder vehicle, unless you plan to avoid hills.
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain
There are dozens and dozens of vehicles that would be adequate, including both Ford and Toyota offerings, but as many have said in numerous forum comments (seriously, search the forum for ‘TV for 400’), you’ll see that we all have our own opinions on what constitutes the perfect towing option for our own individual circumstances.
I’d suggest that while keeping that 5000+ limit in mind, decide what else you want in your TV. Do you want a truck bed, or maybe an SUV? Will you put most of the miles on the vehicle NOT towing? If so, maybe other priorities will have heavier weighting, like ride comfort, reliability, or economy (MPG), and certainly price. Dealer support and accessibility sound important to you already. Maybe safety, 4/All wheel drive, or off road chops are important. They were to us, and helped in our decision as well. You can find options that will meet all your criteria, I am sure.
Ultimately, read up on as much as you can, then decide what you find to be important. But your final decision should come down to what is important to you (proven out by you own observations and physical test drives), and not just what others say is important to them. If you don’t violate the +5000 lb with towing package rule, you will probably find most choices will provide a good to great experience.
nüCamp: 2019 T@B 400 Boondock Lite
I had a brake problem (Dexter) that I think was due to not adjusting them and broke the strings on the screen door. Pretty good service I'd say.
I have done a bunch of mods to make it work for us but very little repairing of the unit. Mostly tightening screws and adjusting things.
Jeff & Amy
From my signature line, you’ll see I have a Ford F-150 that I used to pull my previous 2019 400 Boondock Lite. I fought for decades to not buy a full sized truck as I thought they were not my thing and mid-size trucks were fine for me.
You asked for it!!!....
We have had no problem with our trim rubber flying off.
We have had no trouble with the stove starting.
We've had no trouble with our tires being inflated correctly.
We've had no trouble with the hitch being difficult to unhitch (on fairly level ground)
The Alde has worked amazingly.
Our Maxx-Fan works great.
The blackwater and graywater tanks both seem sufficient, and trouble free.
The mattress works great, esp. with a 2" topper.
No problems with the shower, or toilet (except through user error)
No cracked frame members
No problems with misaligned windows
The list could go on, but it's much more boring than the problems and their solutions....
One thing I installed and would recommend strongly: Sumosprings. About$200 and they take the place of airbags, preventing your tail from sagging and adding a lot of stability. You can install yourself if you have a torque wrench. We have nothing else. No sway bar or anything.
Also, I had a brake issue with my 2020 T@B 400, but Nucamp and Dexter axle resolved it very well for me. You're gonna have issues with any big piece of property; just take em as they come and don't panic. The Internet and this forum are an incredible asset.
