No Hot water
blueangelblueangel Member Posts: 14
I have a new TAB 320S and am having hot water problems.  The Alde system heats up, the water temperature is elevated to about 147 degrees.  The hot and cold water flows with the water pump on (both are at the same unheated temperature).The indoor and outdoor shower are doing the same thing as the sink.  I have emptied and refilled the water tank.  Checked the glycol and it is good.  I worked with the mixing valve and adjusted it to its most open location and then adjusted it further using the instructions on the forum for undoing the screw on top to move it almost to the final end of its range.  The rubber hoses for glycol are hot.  There is no sign of running water on either side of the mixing valve.  The water tube into the mixing valve is room temperature.  It appears that I have a boiler full of hot water, but it is not going anywhere.  Do you have any thoughts about what might be happening.
