I have seen in multiple places, including an email from Pahaque, that ventilation of the trailer is critical to controlling moisture. Even the instructions for the little Caframo electric heater/dehumidifier I just purchased mentions ventilation. I am near Seattle, so moisture management is something I am taking to heart, especially in winter. Question is, how do you ventilate a trailer in winter when it is wearing its cover? Should I slightly open a window or the ceiling vent under the cover???? Thanks all.
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
0 ·
https://www.caframobrands.com/9406caabx.html
I am a little concerned if I open the vent under the cover, that I will forget it is open when I take the cover off and somehow damage the vent cover. I may have to post a sign for myself.
Of course, YMMV, particularly if you live in warmer, wetter (i.e., not frozen) climate.
We had the standard roof vent so to keep rain out that stayed closed.
I opened all 3 windows to the first security latch/barely opened position and pulled the screens down to keep "visitors" out.
Put a dollar tree generic damp rid in a plastic tub on the floor.
Opened the fridge door and put the latch pin back in so the door stayed open.
I checked on it every couple of weeks, especially after a heavy blowing rain to make sure rain didn't get up thru the open windows.
Changed out the damp rid once.
Tampa FL
managed by VE Smart Network
Tab 400BD
TV: 2013 Lexus GX460
Tab 400BD
Tampa FL
https://youtu.be/ipwet25T7Q8
Edit to add: also note that any time you snugly cover something, you’re restricting the airflow inside it, even if the cover is supposedly breathable. Case in point, covering a gas grill can lead to dampness inside it, which can lead to mold over the course of winter. Leaving the grill uncovered but under the house eaves, you have less cleanup to do in spring. Which is why I no longer cover my Weber Q.
Not saying “don’t cover your Tab” here, just that you may well have a harder time taming the moisture problem in a humid climate with a covered trailer than you would if there was simply a roof over it. I’d add a couple of DriZAir buckets in addition to the StorDry if you’re already dealing with condensation issues this early in the cold season.
Now to plan my next outing!
