Victron SmartShunt & battery cutoff switch installation
2»
  • DesertDwellerDesertDweller Member Posts: 129
    For those of you with a T@B 320 and a single 12 V approx 100 Ah battery, what gauge wire are you using to connect the + battery terminal with the + terminal on the SmartShunt?
    2019 T@B 320 S Boondock Lite a/k/a "The D@wghouse"
    2012 Jeep Liberty KK a/k/a "Libby"
  • kbdigitiqekbdigitiqe Member Posts: 163
    @MarkAl honestly the best way to answer your question above about what is our remaining battery percentage is to say I wouldn’t know. That’s because since we’ve upgraded to Li we basically don’t even think about our battery anymore. It’s that much better. We also live and camp out west, so we know that as long as the sun comes out every few days (which it almost always does out west) then we don’t even bother to look at the monitor anymore
    edited November 2020
    @DesertDweller - the red, fused positive cable should come with a BMV kit.  Maybe someone can chime in with the gauge.  I searched all over and can’t find the size in any of the Victron literature.
    I can tell you the fuse for our BMV 700 is a T 100 mA E 250v fast blow cartridge fuse.
    @DesertDweller - found this on a Victron Community forum:
  • MarcelineMarceline Member Posts: 1,732
    Are you sure that you've got this right?
    There really isn't a "+ battery terminal on the SmartShunt"
    There is a Vbatt+ connection from the SmartShunt to the battery. It's a skinny little wire that comes with the SmartShunt and I believe that it provides just enough power to run the brains of the SmartShunt.
    Other than that you should have negative lead from your trailer to the SmartShunt and then a negative from the other side of the SmartShunt to your battery.
    https://www.victronenergy.com/upload/documents/Manual-SmartShunt-EN.pdf
    @Marceline. Doh!  That’s what I get posting a message from memory rather than having the shunt or it’s instructions in front of me. I did mean the negative wire connecting the battery - terminal with the shunt - minus terminal. I did use the supplied red + wire to connect the shunt to the + battery terminal.
    Normally, a 100AH battery would use a No, 4 battery cable, and it should be big enough. Cheers
  • BrianZBrianZ Member Posts: 1,768
    I used a 6G cable.  See here for photos & amazon source links..
    https://tab-rv.vanillacommunity.com/discussion/8051/battery-spaghetti-fix-bus-bars
    Ok.  Thank you everyone.  I installed the SmartS inside my larger than necessary battery box with my original supplied SLA battery from my dealer.  I am able to get BT signal from inside my 320S. The solar controller is under the driver side bench with the other electrical connections, but the controller and shunt see and talk to one another via BT.  Yay!  I have not permanently mounted the shunt yet as I am still considering options.  Thanks to everyone for contributing to this and other related threads.
