We expect to receive our 2021 T@B 320 within the next week or two. I want to be ready with a few things as we expect to camp right away. I realize there are a few good coupler locks out there like the Fort Knox but I intend to buy the Proven Industries. I believe the 2178-A is the correct one right? Assuming so can someone confirm that works with the 2021 as well? I am looking for yes, I know it does, I have seen or done it. Not that it should. Thanks!
0 ·
Good luck with the new trailer!
PNW
Am not aware of NuCamp changing the coupler on recent model years.
Also, FYI.
Chains go in space under the plate that is held in place by the coupler (like a tow ball)
It took me a few tries to get the routine down, but it does fit (at least on earlier models, and I’ve not heard of it not fitting a 2021.)
Appears the Atwood Coupler itself has changed.
Prior year couplers do not have the extra "bottom plate" welded on the coupler so there in spcae for the Proven Lock Plate Tab.
2025 Toyota Tundra / Nashville, TN
@Tabnero - I assume you mean model 2516-E ? Also do you measure 4.5” from the front of the hitch to the bottom welded cross plate ?
We have been made aware of the issue and it has been corrected. You should not have any issue going forward with the Model 2178-A. The Norco specs where just incorrect when sent to us and we have since corrected the problem part of the lock (:
VW Atlas
Asheville, NC
Proven was great to work with on this issue.
