Boondocking Coffee in the 400
12345679»
    pthomas745 Administrator, Moderator Posts: 4,605
    edited January 2021
    The way I see it...this is why owners are piling up the batteries in the trailers. Why spend so much on dual lithium or 6v's and factory installed solar only to huddle in the dark with your Luci lights because you don't "want to run down the battery"?   (This is only partially sarcastic!)  If you can build the Keurig that you can add preheated water to, and then it only uses the 12-15 watts to produce coffee........the RV world will beat a path to your trailer door.
    PS:  there does appear to be a 12v Keurig type coffee maker that only uses 700 watts...but if it takes longer to boil the water, then it would be a wash.
  • Verna
    Verna Member Posts: 6,876
    edited January 2021
    I have a Keurig for my dark hot chocolate, not coffee. While I have a Keurig mini for when I know I will have an electric site in cool weather, but I may leave it at home and keep this Presto My Jo in the T@B.  Heat the water on the stove. Put your K-cup in the slot and then pump the heated water through the K-cup and you have hot chocolate, or hot coffee, or whatever you put in there. It doesn’t take any power, except to heat the water.
  • Denny16
    Denny16 Member Posts: 5,430
    Ananda running an AGM battery below 50% charge will not damage it, as long it is recharged right afterwards.
  • 85Redwood
    85Redwood Member Posts: 52
    I use this single serve coffee maker with the inverter.  It works great with ground coffee or with K cups.  I can make a cup of coffee when stopping for gas...I love it.
    https://www.amazon.com/dp/B07KPTQBF1/ref=cm_sw_r_cp_apa_fabc_KRYT0Q1QGPWRZ87KDQCM?_encoding=UTF8&psc=1
    2021 T@B 400: boondock, 3-way fridge, microwave, solar
    2008 Toyota Sequoia 5.7 L
  • Tabaz
    Tabaz Member Posts: 2,420
    Walmart Mainstays Single Brew Coffee Maker only $19.95.  Use it when I have shore power. Otherwise use the My Joe by Presto. Both use the K Cups.
  • bergger
    Manual grind with a Hario V60 pour over.  No electricity and compostable filter.  Plus it tastes fantastic with my home roasted coffee!
    2021 T@b 400 BD  "Vixen Gail"
  • Tampakayaker
    edited February 2021
    Bclarke said:
    So many great ideas!   But the question I have is.. can I use a small Keurig while I Boondock?
    We have a Keurig press coffee maker.  Guess it’s similar to an aero press.  Very compact.  Put the pod into a holder, screw it onto the bottom of the press which punctures the pod top and bottom.  Place it onto the dispenser, pour in your hot water then push down the plunger.
    This is similar to what we have but ours presses into a small dispenser.  This is probably newer.
    https://www.walmart.com/ip/French-Press-Hand-Press-Keurig-K-Cup-Coffee-Maker-Single-Serve-By-Amazing-Press/111640060
    Tampa FL
  • Denny16
    A French press by any other name is still a French press.  I use a stove top espresso boiler that makes great coffee and stem milk.  Clean up is easy, similar to cleaning an old fashioned percolator.
  • Tabaz
    Link for the $20 K-Cup Coffee Maker:
    https://www.walmart.com/ip/Mainstays-Single-Serve-Dual-Brew-Coffee/772125593
    Love this thing. Removed the lid over the water reservoir so I can easily fill it while it sits on the countertop.  Be careful not to overfill.
  • Gravens
    Gravens Member Posts: 15
    I use a Keurig mini.  Works well on the inverter, only draws power when in use.  The impact of the pods on the environment is the only downside, oh and cost.
  • CJax
    CJax Member Posts: 62
    I'm new to all this... I can't bring my Brera Gaggia?
    2021 T@B 400 Boondock 'Valhalla'
    2018 Jeep Grand Cherokee Trailhawk V6
    veni, vidi, bibi capulus
  • DougH
    DougH Member Posts: 1,110
    @CJax Absolutely.
