MODEL YEAR CHANGES
TampakayakerTampakayaker Member Posts: 558
edited February 2021 in Trailer & Towing
I've seen posts when model year changes occur, but do mods happen in between?
We purchased a used 2016 T@B 320.  It was supposed to be a 2017 per the owner, but when we went to transfer the title it said 2016 so they knocked off another $500 from the price.
The plate on the frame show it is a Pleasant Valley Teardrop manufactured 11/2015
I had located a sheet that showed changes made by year, and it seems like ours has some from 2015, early 2016, late 2016 and even 2017?
Late 2015
Norcold 3-way frig model 3163???  HAVE 3 WAY NOT SURE OF MODEL
Fresh water tank of 11 gallons replaced previous inside 5 gallon tank  HAVE
Gray tank of 19 gallons replaced previous 11 gallon tank NOT SURE
Factory warranty provision of passenger side vent, fan and manual switch to remove excess heat from the Norcold frig.  HAVE
Early 2016  HAVE ALL OF THESE
100% Azdel Backers
Clamp on/screw-free Fantastic Fans
3D Logos
Corrugated underbelly protectant & insulation
No fabric on window valances
Seat panel finger inserts for easy opening
Upgraded cushion foam density
Overhead cabinet doors hinged on top
Late 2016
Shade/screen reversal - Shades pull up and screens pull down  HAVE
Alde display now digital - replaced sliders  HAVE
SeeLevel battery and tank monitors  HAVE
Announced expanded recall of T@B 320 S 1/1/13 through 8/31/16 builds regarding rubber LPG hose laying on frig fins ?
Lagun table and bed slats standard  NO LAGUN, BUT HAVE SLATS
When did they add the pull out steps???  HAVE PULL OUT STEP
Early 2017 Models
Battery disconnect switch??  HAVE
Black tank 8 gallons  NOT SURE
Standard with build - Norcold 3-way frigs vented through passenger side wall with automatic fan. MANUAL SWITCH
Bed rails and slats with cleats to secure the slats  NO CLEATS
Lagun pedestal and table - interior  NO
Struts to support the cabinet doors  NO
Different faucet in the galley sink  ?
Looking at other peoples pictures of those years I see some features on ours and some not on ours.
We have the vent for the 3 way fridge next to our door and a switch for the cooling fan.
We have two round vents under the front window.  I've seen pictures of 1 and none.
We have the bed rails and the bed slats (not sure if they were factory or previous owner mod).
We don't have the Laguan table.
Our ALDE reservoir is under the back shelf/headboard (easy to see and fill) and not in the upper cabinet area.  I've seen people say they use that headboard area for storage but ours has a radiator in it and wiring.
Our fridge doesn't have a freezer.
I'm not complaining we love our T@B, but just interested how we got such a mixture of changes.... unless the sheet with the changes is really inaccurate.
Tampa FL
    You have an old list.  The last time I updated this attached list was in 8/2019.  Since your TaB was made in 11/2015, you have a late 2016 model except no Lagun.
    Early 2015 Models
    All LED interior lighting and oval LED porch light
    Power cord w/ built in LED light
    New style Lexan windows, shades and screens
    Sink in S model wetbath removed
    Black tank of 6 gallons with vent pipe inside shower area (tank under shower floor)
    Radial tires
    Wood-look vinyl flooring
    Late 2015 Models
    Early 2016 Models
    100% Azdel Backers
    3D Logos
    Late 2016 Models
    Factory installed battery cut-off switch
    Yes (as indicated by the details of Sharon's list). Particularly in the earlier years, nuCamp (then Pleasant Valley Trailers) would implement changes on the fly, without particular regard for model year. Ergo, model year was not always a good indicator of the features of any particular trailer.
  • Mellow_YellowMellow_Yellow Member Posts: 355
    One item caught my eye: Announced expanded recall of T@B 320 S 1/1/13 through 8/31/16 builds regarding rubber LPG hose laying on frig fins
    Is there an easy way for me to tell if this has been done on my 2014 or if the LPG hose is still in contact with the fridge? What would I do to address it?
    Look here for the summary documents. A link to the original discussion is also provided if you want to peruse various owner solutions. My 2015 was one of the affected units but the fix was pretty easy.
    Early 2015 Models
    Radial tires
    Late 2015 Models
    Early 2016 Models
    100% Azdel Backers
    3D Logos
    Late 2016 Models
    Thanks, that list make more sense.
    When/what models have the storage in the headboard area, or were they owner mods?  I've read about people losing things down there?
    And isn't the ALDE tank off to the side of the upper cabinets in some models or am I mistaken?
    Tampa FL
    Looks like I have a "late 2014" 320 S - has the Alde and the vent under the fridge :)
    Is there a way to confirm electric vs. surge brakes? Assuming electric?
    Electric has a wire cable that has a pin on one end that goes into a box attached to the tongue frame, and a loop at the other end that you attach to your tow vehicle.
    Tampa FL
    I don't think any of the Pleasant Valley T@Bs had surge brakes, just the older models made by Dutchman. (Someone please correct me if I am wrong!)
    Regardless, the surge brake equipped frames looked very different--silver with a big obvious spring-piston thing on the tongue (see below). Black frames with the cable and pin Tampakayaker described will have electric brakes.
    However--now that I have said that--the image below is from a for sale ad for a 2012 that claims to have surge brakes. It's definitely a different coupler but I'm not completely convinced about the brakes. Anybody know for sure?
    I thought @Verna had surge brakes on her 2014?
    Scott, the bottom photo could be a surge brake, one way to tell, is to see of the coupler head slides back and forth, and look on the underside, you can see the hydro cylinder, or if enclosed a hydraulic hose running back to the axle.
    Thanks @ScottG - My 2014 definitely has the black coupler with the cable and pin setup you show below.  =)
    @Mellow_Yellow (@Sharon_is_SAM), yes, you have surge brakes, a wonderful invention!  Check your brake fluid every once in a while, and have them checked. A utility trailer business always checked mine whenever I had them service my wheel bearings. As I recall, the surge brakes use #5 brake oil.
    You do not need a brake controller with the surge brakes, by the way. I know I wrote in some posts about then. Do a search for surge brakes and read up on them. Interesting.
    Scott, the lower photo shows the surge brakes on my 2014. The first photo shows the earlier surge brakes from the DM/Thor T@B frames.
    @Mellow_Yellow - do you have a brake controller?  @Verna - does she need one?
    @Mellow_Yellow does NOT need a brake controller.
    @Sharon_is_SAM - that is a very interesting question. I purchased a wireless brake controller, but the RV dealer told me I didn't need it because the trailer has surge brakes. My coupler does look like the black one shown in @ScottG's photo and @Verna's comment above.
    Well, your dealer was right😀
    Thanks @Verna and @Sharon_is_SAM! You guys are the best  :)
    It is on my list to get the surge brakes and wheel bearings serviced. At least my T@B was neglected and under-used, vs. neglected and over-used!
    Ok good then. This is why I generally refrain from commenting on things I know nothing about.  :-)
    However, since we are on the topic, I have the impression that the silver Dutchman frames had mechanical surge brakes, but that the earliest PV T@Bs (like @Verna's and, it appears, @Mellow_Yellow's) had frames with hydraulic surge brakes (thus the requirement for brake fluid).
    Do I have this correct?
    @ScottG, I’m not sure with the difference because I have never delved into the DM/Thor brand of surge brakes. I just always thought the 2014 surge brakes were neat and so easy to maintain.
    The DM AK-Lo frame TaBs had hydraulic surge brakes, too, and a mechanical hand brake.  The rubber boot covers the cylinder plunger.  This is an European design.  Verna’s 2014 was a US style surge hydraulic brake, a different design.
    All surge brakes are a hydraulic/mechanical design.  The term surge indicates the forward movement from a TV stopping causes the trailer to surge forward, pushing the hitch back, moving a piston attached to the hitch in a hydraulic cylinder and pushing fluid to the brakes.  Very efficient and effective brakes.  Rental companies normally use surge brakes in the larger utility trailers they rent out, as a TV brake controller is not required.  They are also common in boat trailers, no electrical components to get wet.
    Attaching this very cool! T@B brochure that came along with my pristine "new to me" 2014 T@B 320 S. Seems that 2014 was a banner year for the T@B - introduction of the "wet bath" and the Alde, among other features.
    @Sharon_is_SAM - I haven't seen anything like this posted in "manuals". Feel free to add it. I also have a higher res 6MB version if you prefer.
    @Mellow_Yellow - thanks!  A little piece of history.
