While I admire the Nautilus system, I figured out there is no side "cup shaped" water fill.  Can you bucket water into the T@B? Or does it need a hose? Or a special fitting?
To my knowledge that hasn't been covered on YouTube yet. <grin>
Thanks.
                ...Doug
2021 T@B 320S Boondock, Chevy Avalanche, Happy wife.
0 ·
Is there any way to fill the FW tank without running the pump (regardless of the reason why someone would want to do so)?
Just curious more than anything. I have no desire to trade my 2015. :-)
#1 appears to cover what jkjenn described above--you don't need the pump if you have a pressurized water supply.
This isn't just an academic question. When dry-camping, I top up my FW tank by pouring water from a 6 gallon jug into the FW fill port. While this requires a bit of huffing and puffing, it does not require a pressurized water supply or the use of any battery. I'm conservative with my power and I like having simple options with few potential points of failure. I suspect I am not alone in this regard.
I wonder if a jug with a spigot and hose connector set just above the level of the Nautilus could "power fill" the FW tank just by force of gravity. It seems this would work, provided there are no valves in the fill circuit that require a certain minimum pressure to open.
@DougWW, I think you may have to be the one to test this out! ;-)
I've been perusing the Nautilus P2.5 operating and installation manuals. While it appears my "gravity fill" suggestion would technically work, I suspect it would be veeerrry slow as the FW tank fill line (which is also the FW tank supply line) appears to be only 1/2" PEX.
The Nautilus is a clever unit but what a bowl of spaghetti out back. I remember how the original Alde analog control panel gave people fits. As these newer T@Bs hit the road I'll bet more than a nickel that operating that beast will become the number one source of questions here on the forum. ;-)
I hope that none of those back black connectors need tightening at some point 'down the road'!
I'm sure they just designed it this way to keep us weekend plumbers from thinking we might be able to self-service the things.
"Uh, yeah, I got it all put back together again and, for some reason, when I flush the toilet the shower turns on!"
Jeesh!
I do agree that snugging up the various connectors may be part of regular maintenance. I hope nuCamp is putting these things in places where normal-sized humans can actually reach them.
