A quick camping trip (didn't even unhook and wasn't level) - saw this dripping that I've never seen before. I crawled under and it was coming from a rubber area in front of the wheel well. A friend said she thought she saw a hole where it was dripping. Thinking it has to do with being hooked up to city water as I turned that off and it stopped. Looked under the seating area in the trailer - no water or wet spots. Tried to look in the access door in the bathroom where the pump is but couldn't see down in there. Getting a photo under there was difficult but second photo I was able to catch the drip as it was coming out (circled area). I may not be explaining this all correctly but thought I'd put it on the forum to see if anyone might have a clue! I have a 2016 - 320S. Thanks! Mickie
0 ·
That area is a really pain to deal with. Someone on the forum created a larger access panel - I cannot remember who.
The below discussion thread may be helpful to you. Some of it discusses the fresh water tank connection, but look through the entire post. It includes photos that provide a good view of the campground water inlet connection in the area where the leak is likely located:
https://tab-rv.vanillacommunity.com/discussion/8617/fresh-water-leak-fixed-again/p1
@mickietucs another place to inspect (if you haven't already) is the "tunnel" between the shower pan and the drivers side wall, forward of the wheel well. You might be able to peer up into that area from the under the bench where the converter is mounted.
Unfortunately, leaks can be hard to trace as they seldom drip from where they are actually leaking. Regardless, I would take pains to locate it definitively. If you are lucky it will be an easy fix (or at least easily accessible), but otherwise breaking out the Sawzall may be the only remedy. Good luck and let us know what you figure out.
DEPSTECH Wireless Endoscope, IP67 Waterproof WiFi Borescope Inspection 2.0 Megapixels HD Snake Camera for Android and iOS Smartphone, iPhone, Samsung, Tablet -Black(11.5FT).
Oh the things you can do and see with one of these!
Tampa FL
Tampa FL
