My stove also suddenly started working. I did nothing other than run the Alde off propane prior to it working. I had a newly filed propane tank, having just purchased the Tab 400, and traveled from a cold environment to a warm environment where the stove did not work
Would having an overfilled propane tank prevent the stove from working while allowing the Alde to work?
@Kirk@runaway30 did either of you have this happen again? We just did our 2nd night of driveway camping in our new '21 Tab 400. Our first night (shore power) a couple weeks ago was fine but this second night - boondocking this time - we are having no gas to the stove. Like you guys, the Alde and 3-way fridge are both working fine on propane only, in both shorepower and battery/boondocking scenarios - I even disconnected the propane, made sure the fridge and Alde throw errors in propane mode, and reconnected the propane and restarted fridge+Alde just to make sure they are all seeing the gas and lighting up. I've tried slowly turning propane back on and everything described in this thread but nothing is working. No sound of gas out of the stove either, on either side, when I put my ear to it.
Seems this is becoming too common to be a one off issue - I'm hoping it self resolves as yours did but worried it will become a periodic issue until understood. Haven't called nuCamp or the dealer yet but wanted to check if you have any updates on your end. Or if anyone else out there has seen this problem?
TomCanada My stove has worked just fine since the issue mysteriously resolved itself after the first week of a 16 day trip. There is speculation from NuCamp that going from high altitude (6200') to low altitude affected the propane. My alde was working off propane from day one however. Like you there was no sound of gas at the stove until the day I pulled the drawer underneath the stove and started feeling under the stove for what I am not sure. My wife is convinced this is what "turned it on". I still wonder if there is some spot in the lines for the stove that traps air? I will include the email advice from Creed during this experience.
Runaway30 Regarding your stove,
1.
Propane isn’t something you can really
troubleshoot – when I have issues with the stove not lighting its 1 of 4 things
Propane
tank was opened too quickly, causing the propane not to flow. But you have
eliminated this by disconnecting and turning slowly
Air
in the lines –
the only thing you can do for this is to keep trying the stove until all
the air in the propane line is purged
Bad
propane regulator
– this is the case when nothing on the unit works off propane, including
the Heating system, 3 Way fridge (if you have one), and the stove
Bad
stove –
this is the case when it only the stove that’s not working. I would
recommend taking this to your dealer or a service center near you to have
the stove replaced under warranty.
2.
Try running the Alde off propane by
turning the KW setting to 0 and hitting the propane / flame button. If the alde
runs off propane without giving a gas failure code then it is most likely a bad
stove.
If you had heat coming out of the exhaust
you would have been running off propane though, so it seems you have already
confirmed this.
3.
Me How long should it take to bleed the lines? Answer:
There’s no real set time that it should
work, but from the sounds of it, you should get the stove checked out if it
hasn’t worked by now.
4.
The day the stove came back to life I again emailed Creed and let him know about Kirks experience being similar to mine in that we both went from elevation to sea-level and this was his reply:
Could very well have been air in the
lines.
Thin air at high altitudes can also
affect propane flow. If it seems to be working fine now then I would say you’re
good to go, I didn’t realize you were at high altitudes.
I am glad I had a plan B for cooking (magma BBQ with 1lb gas) and will make sure I pack the camp stove in the future.
Also, a bad regulator or small pin hole leak or obstruction in the supply line can effect the flow of gas. Try turning off the Alde and Fridge propane settings, and see if you can get the stove to light, as the,only appliance using propane. If the stove works on its own, then turn the Alde propane back on. Then check,and see,if you can still light the stove, if not, you have a propane flow issue somewhere.
A previously reported similar issue turned out to be a bad regulator, that was not allowing the proper flow of gas to,the appliances. RV propane systems are low pressure, high volume flow rates. It does not take much to restrict the flow of gas, starving one or more appliances. When this happens, one appliance may work, but not both at the same time. cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
My stove continues to work. I have an appointment on April 8th to have it looked at but will cancel that appointment Monday if it is still working. We did not travel at altitude so that was not my issue. I saw that the stove sells for about $180, but appears now to not be available. Maybe it has been discontinued because of some unknown issue. I believe it has it's own regulator so that could be the problem. I carry my 50 plus year old coleman propane stove that always lights.
The trailer gas line pressure is regulated by the main regulator in the Tub, mounted to the front of the TaB. The stove gets a low pressure, high volume feed fro the trailer regulator. The stove does have a valve and thermocouple for each burner. A bad thermacouple will also keep,the stove from staying on once lit. cheers
I'll post if it quits working.
Thanks for the update. I was wondering from the manual drawings if perhaps there was a secondary regulator that could be causing the lack of flow. I'll call nuCamp early next week and keep checking if it wakes up and starts working.
The strange thing is I'm getting zero flow through either burner valve, but the other appliances are fine so the main regulator should be fine. There's something funny going on in the stove itself it seems..
Maybe a dump question Tom, but are you pushing in on the valve knob when you light the burner? You need to push the knob in, gas flows then light the burner, hold,the knob down for 30 seconds or so, then the thermocouple keeps the gas flowing when yiu release the knob, and the burner is working. cheers
With my model you don't need to push down the knob - you just turn to where it says "light" and press the igniter. That said, I've tried every conceivable combination of pressing and turning and there's nothing I can do to make it flow. It's not a bad question though - I keep hoping I'm doing something truly stupid and someone will just point it out to me
Omg it's working again. Tried this morning and it just.. works. The only thing I did differently since yesterday is that although I turned on the outside supply slowly before, this morning since it was already on I thought I would try to turn the burners themselves on exceptionally slowly, so I very very slowly turned the dial, and then suddenly there was a light "click" (like a solenoid, not ignitor) inside the stove and gas started flowing. From that point on, I could turn the valve off and reopen it as quickly as I liked. Not sure if that was it or it just needed a night to sleep, but it's magically working so as long as it stays that way I'm happy!
Btw I'm at fairly low altitude (300ft above sea level) so the altitude issues known with this stove aren't a factor, and the only other change since yesterday is yesterday the trailer was at room temp but this morning it's cold (around 45F / 5C inside).
Fingers crossed we are good to go, and hopefully this helps anyone else who might encounter this issue. I'll post again if it happens again and if I'm able to isolate better the cause..
Tom, sounds like there is a gas shutoff/on solenoid, that was stuck, and finally released (the click you heard). Glad you got the stove working — makes cooking a lot easier. cheers
Nice TomCanada, i know the feeling. The question remains Why? I used my new stove for week on a trip no issues. Second trip no gas for 5 days and then same experience it just started working. What is triggering this and what is the fix? I am going to make sure we test it as much as possible as far away from home as we can
Runaway
Likewise - I'd still like to know the "Why". Will definitely be keeping an eye on it and packing the portable stove as a backup for a while!
During a FB thread on this exact issue: a 2021 400 with a stove that refused to light. All the general troubleshooting ideas gone through, the Alde was working. Took the trailer to Santa Fe RV, the NuCamp dealer in Santa Fe. Apparently, the issue was "propane residue."
The stove had propane gas residue buildup so no propane was getting to
the stove. So all the troubleshooting above was all correct. (1) try
disconnecting/reconnecting hose, (2) turn line open slowly, (3) try for
10-20 secs to light. (3) Disconnect from shore power and verify heater
and/or hot water is still working (Alde), and if it is seek professional
help.
And the work was covered by warranty and it all took about 20min once we arrived.
The
tech removed the stove and used an air compressor to blow out the
connection. It was definitely the issue. Aldi was working, and the
exterior propane connection was showing gas there.
I'd never heard of "propane gas residue" before, but it is apparently a thing...I just wonder how widespread it would be. Maybe the other owners who suddenly had their stoves start working just managed to work through the residue with the starting efforts?
Second...rumor has it the LP Gods like to have a littel fun once in a while.
San Diego, CA
www.airbossone.com
thats my scenario as well I went from 6200’ and temps in the teens to the desert in Arizona where the stovetop started working.
Then again I did flip the lower toggle switch in the nautilus compartment. You know the one below the pump
Runaway 30
1.
Propane isn’t something you can really troubleshoot – when I have issues with the stove not lighting its 1 of 4 things
- Propane
- Air
in the lines –
- Bad
propane regulator
- Bad
stove –
2.Try running the Alde off propane by turning the KW setting to 0 and hitting the propane / flame button. If the alde runs off propane without giving a gas failure code then it is most likely a bad stove.
If you had heat coming out of the exhaust you would have been running off propane though, so it seems you have already confirmed this.
3.Me How long should it take to bleed the lines?
Answer:
There’s no real set time that it should work, but from the sounds of it, you should get the stove checked out if it hasn’t worked by now.
4.
Could very well have been air in the lines.
Thin air at high altitudes can also affect propane flow. If it seems to be working fine now then I would say you’re good to go, I didn’t realize you were at high altitudes.
Runaway30
Tab 400 2021 (12/18/20 build date)
Runaway
