It all came flooding back to me...the pain and suffering of unbolting the propane tank from the camper for the first time...
I remember being at the Tall Texan Campground, in Gunnizon, CO. The guy at the propane exchange needed me to hold a wrench on one side while he unbolted on the other side.
Is there an easy way to get this bolt loose with one person?
If it's got a regular nut, replace it with a wing nut and put some silicon or teflon spray on the bolt threads?
Tampa FL
I am getting ready to be away for 5-7 nights and need to refill before I go so a friend helped me out tonight.
The nut to the left holds the bolt snug so I can remove the hand nut on the right without a wrench.
Also, did you us the original propane bracket bolt, or did you purchase that as well? Thanks!
PB Blaster is not a lubricant but a bit of anti-seize on the threads before reinstalling the nut would prevent it from binding up again.
The other midwest Columbus! I spent a summer interning for Cummins way back when. Us interns had a good time, but even more fun in nearby Bloomington
@jkjenn Mine came with wingnuts and it came loose without much effort.
