Good idea to do a hard reset in any case!
AirBoss said:May or may not help but perhaps a type of hard "reset" may help.
Remove the square, black cover on top of the Alde. You should see three wires connected to a terminal block. If I recall one is an ethernet lead. Unplug all three of these. Wait one minute, then plug them back in.
Had a similar problem last year and this "hard reset" did the trick. Dunno...but good luck!
