I have looked through the forum and haven’t quite found the answer I’m looking for. I recently purchased a 2021 T@B 320 CS S Boondock with a cassette toilet. I like the option but it’s been very awkward dumping it in disposal stations at the campsite and at the sewer hook up in the RV parks. I noticed that there is some threading on the spout that you poured out from and I’m hoping there’s some sort of hose I can purchase that will screw onto the end of the spout of the cassette toilet and that I can screw into the sewer hook up at the disposal station. Any insight or recommendations? I’d also like to know the best way to clean the cassette toilet.
Thank you very much from a newbie!
Enjoy!
2011 Honda Odyssey/Dave and Karin
Kalamazoo, Michigan
Watch this vid, she really makes it look easy....
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Also keep in mind that a full cassette will be heavy. Depending on your physical limitations, you may need to dump smaller amounts more frequently if you’re going to be lifting the cassette to toilet height.
If you are still interested in some type of hose/adapter to assist with dumping at RV sites suggest you call AVI Casino RV Park; 702-535-5450
During my Jan-2020 stop there they asked if my T@B had a cassette and informed me
AVI does not allow the standard dumping method (described in earlier reply-posts) nor
do they allow dumping direct into restroom toilets. They went on to say AVI requires
an adapter to be used at RV sites & dump station and of course AVI sells that adapter.
My T@B has a black tank (showed them the dump valve) so I did not see what the adapter really is.
Ontario, Canada
https://vintagetrailersupply.com/thetford-to-valterra-adapter-vts-240/
This would allow you to hook up to a dump hose I suppose.
Harpers Ferry, WV
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Also, I doubt very much that this is what the RV parks are selling but once you get to the 2" pvc on the outboard side, you could probably make up any adapter they require with black tank hose and common plumbing parts.
I feel like this could be something used once or twice over the life of the trailer.
I successfully have dumped at all kinds of dump stations as well as FHU sites. Their initial reaction to the cassette toilet was way over the top, IMHO.
Everyone I dump, I am amazed at how easy it is.
Here is a link to the original discussion about the cassette toilet dump adapter: https://tab-rv.vanillacommunity.com/discussion/12783/cassette-toilet-dump-option#latest
