Some of the best information I have seen so farrh5555 said:I'm late to this party, but I may have some insight regarding aluminum corrosion gained from decades of making undersea instrumentation: The inside of the aluminum pipe that runs the length of the radiators HAS to be anodized. If it wasn't, you'd have a horrific mess once glycol/water came into contact with it. Anodizing is a process by which a comparatively thick layer of aluminum oxide is formed on the aluminum surface. This oxide is very, very corrosion resistant. Coloring is also frequently added to make products pretty, too. In a well-manufactured radiator, the outside of the aluminum tube should be anodized too (at least the ends, where the rubber pipes clamp on). What would happen if the outside wasn't anodized (or was badly anodized)? Exactly what is being seen - crevice corrosion that causes the rubber hoses to swell as the corrosion builds up.Why is this happening in some radiators and not others? There may have been a change of supplier to one who cut corners on the anodizing process (the eternal problem of the low-bidder), there may have been a change of manufacturing procedure, it's impossible to tell.The solution: First determine if the outside of the aluminum tube is anodized. A properly anodized surface will not conduct electricity whereas untreated aluminum will conduct electricity really well. You can check this with an multimeter set to read resistance. If the surface is not anodized you need to keep the glycol away from it. Wrapping with self-amalgamating tape (like @db_cooper did) is one option, applying a sealant is another, using heat-shrink tubing (the kind with the meltable lining) would be very effective (if it doesn't get too thick). Then double up the hose clamps, ensuring one is right at the end of the aluminum pipe to stop any glycol from seeping past.I think the frequency of changing the glycol is a bit of a red herring. It probably is mostly to do with replacing corrosion inhibitors, which shouldn't have been needed in the first place!
