Corrosion of Alde Convectors
1…78101213…26
  • Dalehelman
    edited May 2021
    6 years old never been replaced. ph is still 8.0
    1. Hash  T@B Fun
  • Denny16
    Denny16 Member Posts: 5,430
    That explains its appearance when you drained it.  The ph only reflects the antifreeze component of the glycol, not the status of the corrosion inhibitors.  Good luck with the change.
    @Dale - can you take a photo of your Alde hoses?
    ScottG Administrator Posts: 5,693
    edited May 2021
    Sorry to hear that, Dale. I've heard that degraded glycol can turn cloudy, but yours is the first actual report of it I am aware of.
    My recently changed glycol--also six years old--was indistinguishable in all ways from freshly opened stuff, so your findings are yet another wrinkle in the glycol drama.
    Century and other sources have repeatedly claimed that pH is indeed related to the effectiveness of the corrosion resistance, though a pH of 8 is probably on the low end of acceptable and may suggest the start of degradation. Most who have tested their Century glycol (including me) get a pH closer to 9.5. Whether there is something going on beyond what pH indicates has yet to be confirmed. In contrast, freeze protection is typically checked with a refractometer calibrated for propylene glycol.
    Is there any chance the cloudiness you observed is a byproduct of being drawn through your shop vac?
    Yesterday I set out to properly position the Alde's automatic air bleeder. In order to fit it in the provided plastic hanger, I needed to slightly separate the hoses on the aluminum fitting connecting the bleeder to the outgoing glycol hose.
    With the fitting exposed, I tested its external surface for the ability to conduct electricity, and sure enough it had continuity (as would be expected from a non-anodized aluminum surface).
    I might even open up one of the fittings in the near future to check the inside of the pipe, which definitely has a different appearance that suggests anodizing.
    @fstop32, since your system is all apart anyway, can you test the inside of your pipes in an area that is not corroded?
  • BrianZ
    BrianZ Member Posts: 1,770
    Thanks for the great info, @rh5555!
    Great idea about the heat shrink tubing.
    I just received a couple of these anodized 22mm aluminum connectors I thought I'd keep on hand if needed (shown here on an Alde 22mm hose)..
    So, I just put the multimeter on it to check resistance and it was off the megaohm scale, as expected.  Good thing, because they were expensive & cited their design quality & anodizing process meeting mil specs.  So, if you need one of these, you're not totally dependent on Alde parts..
    https://www.amazon.com/dp/B01GQVDCOC
    I haven't started work on our system flush yet, but our side convector looks pretty good from the outside..
    We're approaching the 4-yr mark this fall & no glycol change yet.  Our glycol tank level still sits just below the max mark, and we've never added any.  Most of our camping has been right here in VA, a moderate climate, and we've probably only used the heater for heat or hot water maybe on a dozen trips.  I plan to remove the rear storage cabinet & get a look at the rear convector hoses too.  Haven't drained the system yet, but when I do, will remove a few hoses to get a look inside.  I have some of the sealant on order, but I really like that heat shrink tubing idea, if needed, as the drying time for the sealant sounds like an inconvenience.
    I'm looking forward to your report, @BrianZ. I think yours will be the youngest T@B to have the hoses removed and the stubs exposed, so may provide another clue to the disease progression.
    Unfortunately--unless it's bad enough that bulges have formed--you really can't tell much from the external appearance. On most of my fittings the initial deposits and damage only extended up as far as the hose side of the clamp.
    edited May 2021
    @Dalehelman, I know you said you had no leaks evident, but did you inspect (both by sight and feel) for any bulges where the hoses connect to the convectors or tother fittings?
  • Dalehelman
    @ScottG
    On further inspection. I did find two hose with a slight bulging. See photo. As for leaking zero indication of any leaking.
    1. Hash  T@B Fun
  • Dalehelman
    Here is a picture comparing the 6 year old and unused glycol. Used on the left. The ph is the same with my test strips.
    1. Hash  T@B Fun
    edited May 2021
    Thanks for the additional info @Dalehelman, even if it's not the best of news.
    The upper bulge in your photo looks smallish, but the lower one seems like it's big enough to put some pressure on the clamp. As I suspect you have already determined, additional inspection and mitigation is probably in order, particularly with your full switch to a different glycol.
    These last several comments are more about corrosion than the merits of the Evan fluid, so to try and keep topics from getting too fragmented I've moved them over the corrosion thread from their original location.
  • Dalehelman
    @Denny16
    It is my understanding that glycol level determines the antifreeze level.
    The ph level indicates acid level and corrosion protection.
    1. Hash  T@B Fun
  • Dalehelman
    @ScottG
    Thank you
    1. Hash  T@B Fun
    You're welcome, @Dalehelman. I don't generally tinker with other people's comments but right now we have three related but different interesting discussions going on about glycol and even I'm having a hard time time keeping track of them!  ;-)
    I think I might have to start keeping a spreadsheet on this topic, just like those frame cracks...  :-/
  • db_cooper
    db_cooper Member Posts: 749
    I would trade a frame crack for lack of corrosion. :)
  • pak
    pak Member Posts: 133
    My old glycol also was clear with a high ph. I removed one elbow to check for signs of corrosion and did not see any signs. I checked the inside and outside of the connvector and it has continuity. The connectors also have continuity. As it stands now I am thinking the problem, although sporatic, is due to the connvectors and connectors being raw aluminum. I am inclined, at the next change interval, to get new connvectors and connectors and anodize them. I suspect over the time of my next change there will be a lot more information available. Thanks to all for your inputs.
  • Denny16
    OK, thanks for the update on the pH levels.  I was going by what Alde had previously stated, that the Century fluid should be changed every two years, regardless of pH readings...
  • BrianZ
    edited May 2021
    Haven't yet drained our glycol, but getting closer.  I wanted to first get the convectors exposed for inspection for corrosion later, so tackled the removal of the rear storage bin.  Removing the 7 screws inside was easy, if you have a stubby screwdriver for the three inside the front.  The whole bin then dropped down a couple inches.  The only way I saw to lift it out of the tight space was by grabbing the two cross pieces of wood inside, but there was no room to do this while facing it.  I had to lay on my back like I was bench pressing weights, reach up above my head to grab the wooden bars inside & lift.  It was surprisingly easy this way, though you do need to rotate it forward & get out of the way to lift it all the way out.
    Be careful, because there is a piece of fragile styrofoam insulation on the bottom with a thin covering of aluminum, which serves to deflect heat up & away from the bin.
    Then, I got photos of all the hose connections..
    Closer of hose connections..
    And convector connection on rear driver side..
    And rear passenger side, where I noticed corrosion or oxidation on the outside of the bleeder valve..
    I guess that needs to be cleaned up & coated with something to prevent air contact?
    And closer..
    So that's all I have for now, until I get the system drained & can disconnect hoses for closer ininspection & test with ohmmeter if I can remember to do that.  I guess I could test these new looking surfaces of the pipe connectors now for comparison, as a negative control.  If it fails to give a high reading, then the anodizing by the manufacturer is inadequate to begin with.
    @BrianZ, envisioning your contortions to remove that cabinet brought to mind your detailed tutorial on how to reach the back of the city water port through the bathroom wall hatch. I nominate you for the T@B University Endowed Chair in T@B Yoga.  ;-)
    I note that on the return line from the convectors to the expansion tank, you have a molded elbow making the bend into the tank. My 2015 doesn't have this. I wonder if this was done to alleviate stress on the tank return connector--a common location of cracks in early T@Bs.
  • Tabaz
    Tabaz Member Posts: 2,420
    fstop32 - my Alde hose was also kinked at the bend.  No question in my mind this is what caused the plastic nipple on the bottom of the tank to shear off.
    Although I don't have the elbow, mine does not appear to be kinked. I wonder if it all depends on who was installing that day, how long the hoses were cut, and how they were run relative to one another.
    T@Bs are physically very well constructed with top-notch finishes. I have noticed, however, that very little "artistry" goes into the layout of things like plumbing lines and electrical wiring.
  • db_cooper
    edited May 2021
    No elbow on our 2015 either.  Looks like you will find some corrosion at the aluminum connections. Sorry to admit you to the club @BrianZ!
    The technical details that fascinate some of us are bound to intimidate others--I don't think anyone is advocating panic or trying to scare anybody. Concerned owners are welcome to join the conversation and ask questions, while those who are not interested are free to skip to next discussion.  ;-)
  • Dalehelman
    @ScottG
    I didn’t mean anyone was trying to panic or scare anyone. You must admit that many RVers are not big do it yourselfers. Some may even consider selling for fear of some major impending expense. I just want people to enjoy their unique trailers. If they are not having any problems just change out their fluid and move on.
    1. Hash  T@B Fun
    edited May 2021
    FWIW, I agree with @Dalehelman's sentiment and advice. I've changed my fluid and plan to enjoy a business as usual camping season. I'll worry about problems if and when they become problems--which in my case may not occur in my camping lifetime.
    That said, facts are facts, pleasant or otherwise. I hope the do-it-yourselfers here continue to ask questions and document their experiences. As Dale pointed out, that's how we learn. I like learning--it allows me to keep the unique trailer that I love running smoothly, to make reasoned decisions, and to advise others with confidence. YMMV.
  • BrianZ
    Well, recent posts express some of my mixed feelings about this project, as I'm in a quandary now about just how far I should go, and whether I could do more harm than good (either to my body or our T@B) by trying to clean & seal all the convector connections.  And I assume there are other connector pieces, like at those elbows and on either side of the drain valve.  I tried to disconnect the hose from the drain "T" going to the pump, but didn't have the strength or leverage to do it.  I suspect it may be stuck by corrosion.
    I have forged ahead with draining & flushing our system, and after flushing with both tap & distilled water, I went to what should be the hottest convector connection to see what it looked like..
    So, it has started, but inside of the pipe still feels smooth, so now wondering what to do next.  Clean gently with a wet rag?  Use something more abrasive or would that just accelerate the damage?  Or should I coat with the aviation gasket sealant, or something else.  Or just put the hose back on & double clamp?
    Let's see, we have how many of these, 8?  I wonder if the hose-to-hose couplers are any better? Does anyone know what those look like or how they compare to these on the convector?  The ones on the Alde were fine, even new looking..
    And at check valve..
    I think these convectors are just cheap & poorly made without proper anodizing at the connectors.
    I can say that the 22mm automotive aluminum hose couplers I bought recently are much thicker with smoother edges than any of these connectors or those on the Alde, but expensive at $9 ea.
    Not a whole lot inside the hose at the convector, and it wasn't difficult to remove.
    I will probably look at a couple more & decide whether to keep going.  Maybe will see what the sealant is like.
    On a positive note, I at least got our system flushed and my new 3-way flush valve installed & used it for flushing, which all worked fine.  Will post some of those photos later in the flushing topic.
  • Dalehelman
    Has anyone found any severe corrosion to the aluminum parts. Like holes,  place’s there material has actually been eaten away. Or are we only talking about surface corrosion between  where the hoses and aluminum are in contact with other?
    1. Hash  T@B Fun
  • BrianZ
    edited May 2021
    @Dalehelman, see the photo by @fstop32 from April 2 on p1 of this topic, among others.
