Just starting this project. Box arrived today, so I removed the nuCamp and aftermarket box that came with my (used) T@B. The new box is set in place for reference, but not fastened. The first thing I though of was how it would impact turning radius. Waiting for my wife to get home to hook up and have someone to help keep an eye on it while turning. I'm less worried about backing up. I usually have a spotter to give warnings. It's more about a tight u-turn not hitting the box on my bumper. Any thoughts or anyone have a tub this big? The plan is to partition the box into three sections. The middle will be
used for battery and propane and will be well ventilated. The two sides
will be for storage (nothing too heavy).
Old ....
New ....
https://tab-rv.vanillacommunity.com/discussion/3338/removable-tongue-jack
I went through this with our TaB400, and after looking a several truck style boxes like you got, none of which would allow a standard 5-gallon gas bottle to stand up, we went with the new nüCamp 2021 TaB tongue box, fits better, looks like it belongs on the trailer and is tall enough to accommodate the gas bottle, and came with the proper gas bottle mounting bracket and appropriate vent holes.
Brad
P.S. I think the box looks great.
Concord, NC
Here's a snip of the regulations (may not be current):
Containers. Compartments shall be ventilated at or near the
top and at the extreme bottom to facilitate diffusion of vapors.
The compartment shall be ventilated with at least two vents
having an aggregate free area equal to at least 1 sq/in for each 7 lb
(1 cm 2 per 500 grams) of the total LP-Gas fuel capacity ....
Another interesting thing is that it's illegal to have a lock on the compartment.
Your tool box looks nice, low profile and similar diamond plate pattern to the TaB. The box that came with our TaB was not the original, but a big, black steel truck box, that was mounted backwards (opened from the back, towards the front). Unlike your box AnOldUR, it did not look like it belonged, but something added as an afterthought. Trying to buy a better looking box like yours online that would hold the propane tank, didn’t work, and after two attempts, I went with the new nüCamp TaB box that had just been released.
Now go out and enjoy your new rig and setup!
@Denny16 ... Grommets installed. Thanks for the reminder.
Concord, NC
Trips - 48 Mileage - 63,452
