We have a 2021 T@B 320 S Boondock and are using the Curt Echo wireless brake controller. I am not new to towing but new to using an electric brake controller.
At slow speeds (<25 MPH) when I apply the brakes, the trailer brakes apply fully. This lurches the TV forward. I was expecting a more smooth application of the trailer brakes. I have tried adjusting the settings using the phone app and there is no appreciable change. Is this normal? If not, any idea of the cause and how to resolve it?
2 ·
2017 Highlander Limited
I read that if you hook the Curt Echo in the right order it calibrates better, but frequently I just have to set the gain all the way down to 5 or 10 to avoid jerkiness when in a campground or driving around town... then back up to 50 or 60 out on the highway. Adjusting the sensitivity up or down didn't make a huge change for me in the <20mph towing.
Just sadly a consequence of the convenience and $ of the Curt Echo I suppose.
(previous 2018, T@B 320 Outback)
After adjusting the brakes and considerable fiddling and experimentation with the controller adjustments, the problem went away for good. I have a reasonably substantial tow vehicle so I keep the brakes dialed in pretty low, but they do work.
Referring to the OP's question though, the brakes will get applied fully as indicated by the orange circle whipping around the phone display to 100%, if the Echo isn't initialized correctly. It's absolutely important for the Echo electronics to initialize with the Tow Vehicle running and the T@B not connected. For example, the Echo can't be unplugged from the TV and left attached to the T@B, then replugged. Here's a summary of the proper sequence:
1) Start the Tow Vehicle, open the phone app, and plug in the Echo without the trailer connected - you should see the blue blinking LED, then the Blue solid LED once it syncs with the phone app.
2) Plug in the T@B, the LED should fast blink yellow (calibration phase), then end up at solid green - ready to tow.
Once initialized, the Tow Vehicle can be stopped and started during normal travel but once the Echo is unplugged, the above sequence had to be followed for things to work right... at least for me. Good luck!
- I plug into TV, but I don't launch app yet. I plug in trailer, *then* I launch the app, and when I'm solid green I know I'm good.
- I might do the above with the car off - because I still get power to the 7-way connector. Once sync'd and I'm ready to go, I start the car and off I go.
Could one of the above be causing my grabby brakes issue? I wouldn't suspect a phone sync would be required to ensure a proper calibration before the trailer is attached. And I would expect calibration performed with TV off should persist after I start the TV. But now I'm wondering if I follow the exact steps @mreric listed if I might get around this. Hoping to get out this coming weekend so will try it out!
Set them for a comfortable grab at the driveway, back up and forward to confirm, take it out on a drive and continually check the "grab" level for your comfort. Mine did the same and it took some practice to set it up for my driving style. I prefer a minor lag before the brakes grab so it will not hammer the TV in flat road and around town. Setting up the sensitivity and the amount of braking force should be done individually. So you can get used to which control satisfies your immediate need. Presets are great too. Mountains are a pain so setting up a stronger brake is a must. No one wants to pushed into a downhill curve. If you can start off with a simple cold rotation and see if one feels tighter ( slows faster) while being spun while elevated. Mine was almost new and had a lot of drag on one wheel. Hope it helps. FYI The Echo has been working great, every problem I had was related the trailer, or me. Operator error.
2019 T@B 320 S
2021 T@b CS-S
2022 T@b 400
2021 Chevy Colorado
2021 Toyota Tundra
CO Rocky Mt's, Coast of ME
Poughquag, NY
2021 T@b CS-S
2022 T@b 400
2021 Chevy Colorado
2021 Toyota Tundra
SW Colorado
Apparently, it uses you position to determine speed. Yes, this is not in the instruction book. Haven't had any problems since.
Earlier comments hit on an important point. The effectiveness of braking is dependent on the brakes being adjusted so both brakes apply equally.
"Just Enough"
That said - maybe that's where things start to make sense? *If* the controller is actually using the speed of the vehicle as an input to its brake strength calculation, then it stands to reason if the connection is broken (or the speed isn't properly transmitted due to phone not giving location permissions to the app), the controller might assume "I don't know how fast I'm going, so I'm going to assume I'm going really, really fast, and apply the brakes accordingly". This would be a terrible algorithm, since the internal gyro/accelerometer of the controller is what's supposed to tell it how hard to brake, *not* the speed of the vehicle. But it's possible - if this is true, it could explain my case (due to poor connection with phone) as well as other cases (if location permissions are not given to the app). Can anyone else confirm? My Tab is in winter mode and not moving for a few months - but if someone else wants to give this a try, let us know what you find out!
I've got a new TV and plan on ditching the Echo and going with a Tekonsha hard-wire, but if we can get Echo behaving, perhaps I'll save a few bucks and give it another go..
I will add, if something happens, you moved too far from the rig on a stop, etc. to brake the link, it doesn't work consistently. It supposed to continue on the last settings, but sometimes odd things happen. For consistent operation, we do the sync dance at every fuel and food stop.
"Just Enough"
1) when I am just driving slow through a town, is it safe to just turn the thing down to zero?
2) I have a trip into the mountains coming up, I am very worried that it will be grabby on the descent. Any sense as to whether it will behave more like it does on the highway vs town when I am in the mountains? I have no way to test this out before the actual trip. Kinda worried about grabby brakes on steep twisty roads.
I am getting my brake adjustment checked, and I can report back after that.
Starting with the output adjustment, drive forward on a dry and level paved or concrete surface. At approximately 25 mph, apply the vehicle's brakes. If trailer braking is insufficient, increase the max output setting in the brake control application. If the trailer brakes lock up, decrease the max output. Repeat this process until stops are firm, just short of lock up.
Once the output is set, adjust the sensitivity by driving forward at approximately 25 mph and press the brake pedal. The vehicle and trailer should make a smooth stop. If the stop seems slow and more aggressive braking is desired, increase the sensitivity level through the brake control application. If the stop seems too aggressive, decrease the sensitivity level in the application.
Make several stops at various speeds and adjust the sensitivity until stops are smooth and firm. Slight adjustment to the output control may also be desirable.
Best guess I have is if we don't maintain a constant connection between phone and controller, the controller will decide to go full strength with every subsequent application if the brakes. Which is fine at higher speeds because it's smoother, but becomes extremely jarring below around 30-40mph. And worst at crawling speeds. Notice the manual says the APP doesn't need to stay on; however, it doesn't say anything about BLUETOOTH needing to remain connected even when the app is exited, and that's where I suspect the issue lies. This also aligns with the fact that early in any given trip, the brake engagement is typically fine, and it's only a bit later it starts getting grabby at low speeds (even with dials turned down to min for sensitivity and strength). That tells me that early on when the Bluetooth connection is still solid, everything is happy, but later when I lose Bluetooth (and it happens a lot, in both my tow vehicles) the grabbiness begins. Correlation for sure. Now trying to figure out causation. @Mickerly 's observation of moving away from the rig (disconnecting) being linked to this problem is also another data point confirming this hypothesis.
We have a trip planned in a couple of weeks. I plan on using the app on an old phone (or maybe even my main phone) and leaving it in the trunk very close to the hitch to maintain a reliable connection. If the problem goes away, I think we have our smoking gun.
In the meantime if anyone wants to beat me to the punch with that experiment I welcome it and hope you can share your results here!
