Anyone know where to order a replacement 30 amp receptable that is on the outside of the Tab 400. I got to campsite last night and when I plugged in I had no power. Power watchdog device said everything was good from the pedestal and the lights were lit on the power cord. But nothing inside. I tried flipping all the breakers back and forth. I noticed this morning that two of the prongs are loose in the receptacle. Either that or wire came loose on the road. Was working when I left as I was plugged into cool the fridge down.
Thanks for any help
http://www.doityourselfrv.com/30-amp-smartplug/?utm_source=newsletter&utm_medium=email
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
You do have to also spend money for the SmartPlug cord end, but if you're handy, you can retrofit an existing cord with a replacement connector. One costs about $70-$100 but is less expensive than buying a complete cord with a SmartPlug connector.
There's still a weak link in that the end of the cord that plugs into the shore power source has the usual prongs and twist issues, but that point is a better place to have overheating vs. on the trailer itself.
2023 T@B 320 S Boondock
