I'll preface that we love our trailer so far. Granted it's a bit early as we just returned from our shakedown trip but we definitely see this getting used quite a bit. The materials and design are amazing compared to what's out there currently.
Where things turn sour are in nuCamp's lack of apparent QC. Upon receiving the trailer we had a slew of cabinet issues. Most were minor and required me to wrestle with cabinet faces and slides to get drawers to line up and close properly. Also, many fasteners were simply over-driven and I had to do the old toothpick and wood glue trick to get them to bite again. Woodworking tip...don't use an impact drill on tiny screws.
While all of these were an afternoon of work for me to correct, there lies a larger issue with the upper cabinets being racked (not square as you face them...more trapezoidal). This might require a complete removal of that upper cabinet to rectify...still investigating.
Finally, this weekend two plumbing issues came up. One was that the Hepvo valve under the kitchen sink wasn't even tightened so water began spilling out of it. Raised the grain a bit on the shelf but I was able to tighten and all seems to be good.
Second issue was the dreaded black tank flush not being tightened completely on the backside of the Nautilus panel. I know many people here and on FB have mentioned theirs wasn't tightened so I was ready with eyes on the back of the panel and sure enough it started streaming water from the connection. Again, tightened this and all seems to be fine.
If you're a new owner I highly advise you to do a driveway pressure test of your water system as well as the drains. We did this but didn't test the drains and the black tank flush.
Don't get me wrong, even after all of this we're thrilled about the 400. Warranty has been amazing to work with and is making sure we get parts for a few minor issues we've run across but my guess is they wouldn't be so busy if QC was doing their job in the first place. It's concerning that nothing is being pressure tested at the factory. And when I asked our tech at the dealer about the reported issues about the black tank flush leaking he assured me that "I tested it and everything works"...umm, ok buddy.
At any rate, this isn't a rant. I just hope those new owners see this and follow our advice. I've been in touch with nuCamp about all of this as well. Just hope they iron out these issues so new owners won't have to go through all of this.
2021 400 BD
2020 Tacoma TRD Off-Road
2 ·
Where the problem gets magnified are in a couple of different scenarios.
1. Workers are not following the "standard work flow or procedures", I could list dozens of things I have personally seen.
2. The inability to do the work in the "standard work flow fashion.
I believe the problem today is related to #2; that things are not being assembled using this "standard work flow" from beginning to end. Instead, things are partially built, pulled out of sequence and put back later when the remaining parts are available to complete the assembly process. This creates so many more possible failure points than can be imagined.
Not meant as an excuse, but more so as an explanation to what I believe is going on.
Brad
Concord, NC
Yeah, I totally agree with you. I think anytime you have gaps in workflow you introduce room for error.
But I would add that if a proper and complete QC was done then most of these issues would've been caught. They should be pressure testing units prior to shipping. They already winterize them so just spend the extra time testing the lines before winterizing. Now they're stuck handling a multitude of warranty claims and complaints (time and money). Just seems shortsighted.
Disclaimer: No direct NüCamp data, comments based on various 'factory tour' videos of several different RV trailer manufacturing companies.
Believe most RV manufacturers use a product Quality Sample Inspection method. One of every N units built is given an in-depth inspection including operating all (non-water) systems and leak pressure checks. If issues are found the 'build station' is inspected/corrected. The non-inspected units may or may not be inspected for that manufacturing error based on company policy and resource variables. Focus is on correcting future builds not reworking completed units.
As for "factory" Winterized . . . all water systems are dry. No water so no freezing concern.
As I said . . . just an opinion based on watching lots of factory tour videos across the RV industry.
You can see this procedure on Paul the Air Force guys factory tour videos for both the 320 and 400 TaBs.
SW Colorado
I think for the kind of money we're paying these units should be bulletproof from the factory but maybe I expect too much. We had a Forest River popup before this and it was a mess. But for the money we paid I was somewhat ok with it. A lot of people like to crap on Chinese manufacturing but sometimes I have to think "Are we much better?".
Freezing climates can damage the camper’s plumbing system and equipment. The camper must be drained, blown out and have antifreeze protection before storing or camping in below freezing temperatures in fall/ winter. This is done through a process called winterizing. When getting the camper ready for camping season in spring you must cleanse the potable fresh water system to remove all the antifreeze. This process is called de-winterizing or sanitizing. User instructions for winterizing, de-winterizing and sanitizing can be found on the Nautilus plumbing control panel manufacturer’s website at:
Microsoft PowerPoint - Nautilus-P3-User 2 (bandbmolders.com) and found on p12 is winterizing (full monty) , no reference to dewinterizing, and nothing on "factory" winterizing. It's hard to keep everything sync'd--I know that from experience.
So I'm adding my 2 cents to the QC comment even as a newbie to add to the things you and others have mentioned, with the caveat that relying on inspecting in quality seems like a lost cause. I have a drawer that doesn't shut flush on both sides, for example. Whatever failproof jigs they're using to put screws and hardware in don't seem up to the task (as in not failproof). And their hardware quality can be flummoxed by putting check valves in backwards or simply not tightening a "hose" like fitting.
All of that said, it's a beautiful trailer (the design is quite something), and they do seem to care even if my dealer is just cranking them out the door. We're impressed.
And yes, one of my biggest gripes is not having a quick reference on how to actually use the trailer. Yeah they have a manual but it doesn't really walk you through step by step. I'd love to see a manual that has scenarios like "hitching/unhitching", or "at a dump station". I had the hardest time with the Atwood coupler at first until I realized you have to pull forward just slightly to allow the hitch to release the ball. Just little things like that.
Thank god for YouTube and people wiling to make content to help us along.
Things like the cabinet doors out of alignment are things I’d almost rather fix. It gets me familiar with the trailer’s inner workings so I know where things are. I’m a compulsive DIY’er not just because I can save a buck; I usually learn a ton doing it on my own.
As an aside, allowing parts problems to interrupt standard work in order to maintain a delivery schedule is a quality system red flag.
I can't speak to NuCamp's QC method because I have not been to their plant as a vendor or a customer. If indeed they are doing a random QC sample, that would be an easy fix. The cost of any warranty repair VS. fixing it at the plant before it leaves is pennies on the dollar in comparison. The people added would easily pay for their compensation package by reduction in warranty claims.
Brad
Concord, NC
"Growing old is mandatory. Growing up is optional."
I have read this thread several times and I appreciate how frustrating it is to have our highly regarded TaBs delivered to us with manufacturing issues. Owners come to the forum to report issues and to find assistance from fellow owners and that's great. However, keep in mind, of the issues you see reported here, there are many more owners who do not experience manufacturing mishaps, but they don't report it! So, it starts to look like there are far more issues than what truly exists. This is not meant to minimize owner's repair issues, but rather to keep our perspective with new and ongoing issues. In this vein, there is always room for improvement by any manufacturer, and I do not think their QC is terrible as the thread is titled.
NuCamp has reported a 1% warranty claim rate, which is a leader in the industry. QC is an ongoing process that nuCamp does take seriously. I have spoken personally with the QC manager. He reports that with the exception of making more campers each year, nothing has changed with the factory work process, so please stop speculating about their QC process. It does not add value to the discussion.
Enough said. I ask that you respect that nuCamp graciously provides us with this very worthwhile owner managed forum. In addition, if you have ideas that would serve nuCamp well, please feel free to write an email to Help@nucamprv.com. I know of no other company that will take your feedback and comments to heart like nuCamp.
Verna
If we aren't allowed to speak our minds then what value is nuCamp or the community getting from this forum? If everything is just positive (and there's A LOT of positive posts here which is great) then what's the point?
For example, the leaking Nautilus issue...if I hadn't read this forum about others having the same issue then I would've had a flooded trailer. Conversely, this forum gave me the confidence to go with nuCamp because of all of the praises people have given to the quality of their product and amazing warranty (something I've praised in this thread).
An owner-created forum is a double-edged sword and nuCamp knows this. Show me any forum that's just full of positive feedback. They get to glean valuable insights both positive and negative and the risk is they might have some complaints. I love the nuCamp philosophy but I also feel like making these particular issues public will help soon-to-be owners know what to look for vs. being in the dark.
We LOVE our camper. We fell in love with the German-made 400 6 years ago and have been on a mission to own one since then. After coming from owning a junky popup trailer and researching pretty extensively the competition this is like owning a BMW. But like a BMW, certain aspects of the trailer should be bulletproof. This is why I've been so shocked by the lack of QC on our camper. These are EXPENSIVE campers and along with that expense comes the expectation that it arrive to customers with minimal problems.
I didn't start this thread with the intention of crapping on nuCamp and I think if you read the entire thread that's clear. I started the thread because I want other soon-to-be owners made aware of issues that MIGHT come up. I appreciated the Nautilus issue heads up and I'm trying to pay it forward.
