I am planning my trip and one of the sites I really want to stay at only has 50 amp service. Can I SAFELY use A 30 amp/50 amp adapter?? My mind says no, but I would like someone more experienced than me to say Yes or No. Thanks, Bob
Bob & Irene 2003 F150 V6-Manual
2018 TAB 400
Nashville, TN.
0 ·
https://www.etrailer.com/faq-30-amp-50-amp-rv-service-adapters.aspx
Brad
Concord, NC
In short, the amount of current (amps) flowing is determined by the device in use, not the maximum capacity of the service.
Brad
Concord, NC
Brad
Concord, NC
2018 TAB 400
Nashville, TN.
That said, I don't know how or if the code applies to RV installations, so I won't take your bet since codes are often based on obscure "what if" circumstances. Regardless, under normal use your RV cord should be fully protected by the T@B's main 30A breaker.
@cowboypete, a power surge is not the same as an overcurrent condition. A power surge is a transient spike in voltage that originates on the grid/pedestal side, while an overcurrent is excessive amperage demand that originates on the camper side. While RV surge protectors and EMS devices probably also incorporate overcurrent protection, I would not assume that one necessarily protects you from the other.
https://mortonsonthemove.com/can-you-hook-a-30-amp-rv-to-50-amp-power/
edit to add:
This is one of those grey areas where you have to decide what level of risk you’re willing to take. Even if you have an onboard EMS, using surge/over-current protection at the breaker box is cheap insurance. And speaking of insurance, in the rare instance that there is a problem, you probably will not be covered for the damages.
I like that they also emphasized the difference between surge and overcurrent protection, and the need for a device that protects against both if that is your intention.
