Hello all,
I just purchased a used T@B and the Victron 75/10 isn't charging the battery during the day. The batteries are two 6 volt Trojan T105 flooded lead acid wired in series.
The battery State on the Victron remains off. I've checked the fuses from the solar panel to the Victron and the fuse from the Victron to the battery and those are both good. The Victron app indicates there is Voltage and the battery is at 12.1 so it defiantly isn't full.
When I click on the App it says that the battery charge is off for reason 1. Insufficient voltage or short circuit.
I reached out to NuCamp and they indicated that because the Victron needs to be +5Vdc over the battery voltage to start charging and the solar panel max voltage is 16.42 that the battery voltage would need to be 11.42 or lower for charging to start. This doesn't seem right, as that would require the battery to go to 0 charge before charging starts.
Any thoughts on why the Victron remains in the off charging state? Has this come up before? Any suggestions on troubleshooting steps I could take?
Sincerely,
Aaron
0 ·
Here is a YouTube Victron produced explaining this exact thing - because it does come up pretty often as most of the other controllers don't do this.
If it is from the Victron reading, are the panels in full, direct sun? My panels (non factory) all put out over 18V when in direct, full sun. When the panels are partially shaded, cloudy day, etc. I get less voltage like you are reporting.
Hope this helps...
2019 320 Boondock Edge - Sold Jan 2022
Charging isn't turned off on the App. I double checked that.
16.42 is the spec on the panel. See attached spec sheet.
https://tab-rv.vanillacommunity.com/discussion/14045/solar-not-charging-battery#latest
If you see the Victron showing better than the 16.42V (i.e. 18V) on the panel, you may have a wiring issue.
If so, here's some 'bench racing' type diagnostic thoughts:
*I've read on the forum that on occasion the system is mis-wired at the factory (positive and negative wires switched between the panel and the Victron). I don't know what your Victron panel voltage reading would be if this was the issue.
*I experienced a wire work loose from the Victron and had a lack of charge that mystified me once (Full voltage reading on the panel but no charge happening). Check the screws on the Victron.
Not saying these are your issues, but something to look at...
Also, I'm attaching a few screenshots of the app screen.
Thank again everyone!
Aaron
You are correct, you would not have any voltage reading if the solar panel was wired backwards to the Victron controller.
You should however be seeing readings in the 18V range if you have a "12V" solar panel.
Most solar panels will still produce near their full voltage even under very minimal sun conditions (they'll just produce very little amperage or watts).
You're correct, there is either a problem with your panel or the wiring from the panel to the controller.
The open circuit voltage of your panel is 21.25V (panel voltage without a load), and you should be seeing in the mid to high teens most of the time. That panel should work perfectly with the Victron and has plenty of voltage to achieve the +5Vdc charging voltage required.
And just BTW, SunFlare are high quality solar panels, not withstanding that yours may have a defect - but my bet would be on the wiring. A bad crimp connection creating high resistance for example.
This is on a 2021 T@B?
I could start with the fuse wire. Cut that and recrimp it. It looks solid but that would be the easiest place to start.
I'm not familiar with the 320's wiring.
Is the 4V measured directly via multimeter or via the Victron app?
The voltage dropping sounds like a bad solar panel...but unfortunately you can't rule out just a bad connection.
Thanks for all of your help! I’m going to reach out to Nucamp and see what they say about the warranty.
What you are describing is eerily similar to what happened to me with our, "new to us" 2020 400 BL. I assumed that as a first time RV owner that I was at fault for not managing my usage. After a great deal of head scratching the panel was tested by my RV repair techs and the panel was taking in only 4w in direct CO sun. Until they put the new panel on, they assumed that it was a faulty panel. Well, to everyone's surprise when they put the adhesive on the new panel to lay it on top of the burned out panel (to save the roof), they noticed that the shipping plastic was NEVER removed from the original panel! I will save you all of the drama of the time invested and hoops I needed to jump through to get the extended warranty finally settled, but I LOVE my new panel! Works great and the APP doesn't read ZERO anymore!
Long shot for sure....but hey, climb up a ladder and try to peel the protective film off......
Can't make this stuff up!
Good luck!
2017 Tacoma TRD Off Road
Toronto, Canada
So the big question is now that you've removed it, does it work?
(Sorry for the confusion of the post...I was thinking of the NEW panel which is a Xantrex 220W.)
