After working recently on both propane and shore power, our Alde decided not to work last night. Fuses looked good but I changed them anyway......didn't solve the problem.   I have the electrical cord at the Alde zip-tied so it doesn't jiggle loose on rough roads so that's not the problem.   Glycol fluid is OK.  I checked all the fuses in the converter box and tripped and reset the breakers, still doesn't work.  What am I missing?   Our T@B is a 2015 model with the 3010 version of Alde.
0 ·
Have you noticed any problems charging your battery while on shorepower? Trying to rule out any converter issues.
OK...nevermind what I asked then
There is a discussion regarding replacing the Alde thermal fuse. Chan did this. Or, you may need a new circuit board or maybe just a new controller.
Anyone else have any ideas?
Transwest Truck Trailer RV
Address2224 Sanford Drive, Grand Junction, CO 81505
Websitewww.transwest.com/
Phone+18005715791
DirectionsShow directions
Service TypeAlde Partner
That the Alde works on battery suggests that the Alde itself is fine, as is the circuit connecting the Alde to the WFCO power center (usually called the "converter" but the converter is only one component of the power center). This includes all the fuses as well (which you have already checked).
That all other 12VDC devices (lights, etc) work when on shore power suggests that the converter itself is fine.
That the Alde doesn't work AT ALL on shore power with the battery disconnected suggests that the Alde 12VDC power circuit is not getting power from the converter.
This would be a very odd circumstance, but could derive from a broken or loose connection internal to the power center. Unfortunately, tracking that down or even suggesting where to look is outside the scope of my experience. Good luck and let us know when and if you get it sorted.
