Forgive me if this has been covered a million times. Have 2018 cs-s and spent evening at a harvest host in GA last week. By the morning, our single battery was so low, that the lights would not come on. So, was thinking that maybe two battery set up is best. So, is that two golf cart batteries? And, if I am not the guy to set up, where do you go? Do you go to an RV place, or an interstate battery location? I read, if I recall, you need to set up the two properly to avoid burning out the system. Thank you, and again, apologize if covered, I am sure, already.
0 ·
Also, FWIW, that box will accommodate an Interstate group 31 battery as well.
I've never been a big fan of keeping batteries on chargers at all times. A good battery will hold a decent charge for some time. I just keep an eye on them and top up before trips, or as needed in the off season. Others keep their batteries on chargers (including the charger built into the T@B) full time and report no ill effects, so bottom line is I guess you can do whatever floats your boat.
That said, when you say "trickle charger," I assume you are talking about a modern smart charger. These will sense when the battery is full and taper off their charge current as needed so as not to damage the battery. The same can not be said of traditional trickle chargers--these should be removed once the battery is fully charged.
I also agree with @pthomas745 about battery monitoring. I'm on the "keep it simple" and use a basic voltmeter, but these do require some battery whispering skills to interpret what they are telling you. Lovers of tech and those with deep pockets prefer the more intelligent monitors such as those from Victron that eliminate any guesswork.
That $100 group 27 battery I installed (along with a 100W solar panel) lasted five seasons. It's still in ok shape but was starting to show its age. I now carry it as a spare, though I've yet to need it.
That's how I started. Once I had a good sense of how things worked I reconfigured my system so I could get the controller under cover and closer to the battery. I've used the same Renogy 100W panel and controller for six years now and it still gets the job done... so long as there's sun. ;-)
Now, as soon as I hook up for a trip and turn on the battery, I run around and open the CS and shut off the light. Battery doing much better.
