Our first time boondocking 2022 320 CSS BD. Besides feeling Smart Shunt illiterate, we are quite memory-challenged, but hopefully someone will see an obvious clue in our reconstructed diary.
Day 1 – Had parked in driveway x 2 wks
Turned on Alde midday to test system for boondocking
Temps 40-60F cloudy/rainy
Day 2 – Trailer warm but no power in am
?? Smart Shunt reading 11.?
Plugged into shore power @9a
Fridge turned on and set to #3
Day 3 – Fridge to 30 degrees and loaded @9a
Road travel @9a x 7 hrs
Temps 50-70F sunny
Shorepower @4p
Day 4 – Road travel 10a x 7 hrs
Began boondock @6p
Temps 45-70F sunny
Trailer battery indictor – “Fair”
?? Smart Shunt reading “11.?”
Alde set to 65F then 63F for overnight
Day 5 – Used 12V food warmer x 30 min @7a
Fridge warming so turned up to #4
Turned off Alde @9a
Temps 45-70F sunny
No trailer use x 5 hrs
Alde turned back on @8pm
Power went down @10p
Carbon Monoxide/Propane chirping
Disconnected Battery and plugged into TV x 1.5 hrs
Reconnected battery
Alde set to 63F for overnight
Chirping again and disconnected battery 2 or 3a?
Day 6 – Plugged into TV x 2 hrs @ 8a
Alde turned on x 2 hrs
Alde turned off a 10a
Temps 45-65F mostly sunny
No trailer use x 2 hrs (lake)
Disconnected Smart Shunt/reconnected original wiring
Reconnected battery
Day 7 – Power went down @5a
Jensen, display, etc turned off, no chargers, 12V nor lights, etc used
Day 8 – Alde on all night and still had power in the am
Road travel @ 7a x 10 hrs
Plugged into shore power @5p
To avoid running into issues in the future upgrade to a higher capacity battery. Does not have to be Li-Ion there are good AGM batteries as well, though heavier. Maybe add some solar to it, personally I like external panels that can be moved around with the sun (few clouds but tall trees where I mostly camp). FWIW my older 320S with the much hated on Norcold 3163 and a 40W external solar panel can do 3-4 days off-grid without pushing it.
It does sound like you may have something else going on in your wiring or setup but with the 2 way fridge and even carefully constrained electrical use, the 'typical' stock battery the dealer puts in isn't sufficient for serious boondocking based on my experience.
The electric refrigerator is a mixed blessing. It is so much better that the gas unit at keeping food cold. But, it will draw 2.5 to 3 amps per hour. The Alde heat is amazing, but will draw about 2 amps per hour. If nothing else is on, you are using roughly 5 amps per hour. This is where the battery size comes in. The 320 battery is installed by the RV dealership. They choose a small one to save on their cost. If you have a 65 amp Marine battery, only 32 amps are usable. That's 5 hours of heat and refrigeration.
Solar panels need sun and operate best perpendicular to the sun. You had cloudy and rainy and the top of the trailer is curved. The sun needs to be high enough to get a good angle on the panels. So, you can't count from sunrise to sunset. Subtract about 2 hours from each end of the day. Portable panels let you aim them to the sun and collect more power instead of aiming the trailer and hoping for the best. Once the battery is 'well used' it takes a full 8 to 10 hours of charging. Your 100 watt panel will provide about 5 amps per hour of charge "under optimum conditions". Being curved outwards, its very difficult to aim the trailer to get optimum conditions.
When we first got our trailer, each trip as an opportunity to learn something. There are tables on this forum showing how much power each item on the trailer uses. The tables are for older trailers than yours so they won't be perfect, but will work. Without looking, I can say the battery is the weak link in your system; just like ours. How you intend on using the trailer will determine what is correct for you. If you plan on a lot of boondocking, a bigger battery, possibly Lithium and a portable panel may be a good idea; however, expensive. We boondock very rarely, so we are staying with a lead/acid battery, but I'm looking at portable solar for those few outings without hook-ups.
Take a deep breath. All is ok. You'll figure this out.
"Just Enough"
TV 2025 Telluride X Type
@VictoriaP Standard Stock 100w panel and Group 24 battery
@Denny16 Yes, we were wondering if we connected the Smart Shunt correctly. We’re going to rewire it back up and upload a pic of it in a bit…
@pthomas745 YES! Yosemite w/o the crowds was a lot of fun! We were saved by nearby ice stores, and all else felt like little bumps. Just mostly disappointing for our future spur-of-the-moment boondocking dreams thru the winter.
We did get some Victron 11.__ readings in the beginning, but eventually didn’t trust it, or just don’t understand enough about them. Our brains loss power too in the driveway, so we can’t remember if we ever got a 12+ reading after that, but don’t think so.
Yes, with that much sun, driving and shore power in the beginning was baffling. And then to eventually be okay on the last boondocking nite after less sun, driving confused us even more, making us question our Smart Shunt set-up, settings, understanding, etc.
@Marceline While in driveway the battery switch was on :(. Lesson learned. However, I guess I’m not sure why being plugged in for 24 hrs, then driving in the sun all day, then being plugged in again, and then another day of driving in the sun would not have got us back up to a fresh start.
@Grumpy_G LOL “boondock.” Frustrating side note was we chose to not order the boondock package and added a solar panel. But they shipped the wrong unit . However another dealer had what we ordered but w/boondock. They split the extra cost (or we could have waited another 2 months). Unhappier in that I have not been able to grow another 4” to be able to reach the top of the clamshell hatch.
@Mickerly I’m very interested in the looking at the “tables”. Can you pass on either a link or better search word than one that gives me lots of posts on lagun tables? I think changing out to a 3-way fridge might not be doable in light of other priorities. However, because we like to camp cook (a lot), we definitely need to do better w/ice chest cooling to not rely on having/using the frig.
@mntrails and @Freespirit If it turns out we have the Smart Shunt set up right, the ‘boondocking over-expectations’ of our delivered trailer makes a lot of sense to me. Disappointing to not even get one sunny day w/o losing power. Between both of your boondocking 4-15 day less-sunny practices, I’m hoping a battery upgrade will be a start for us to be able to depend on boondocking days whenever we want/need/have them. Our one time (pre-t@b) use of a portable solar in the woods, makes us put that lower on the upgrade list, but rather makes us want to dig into your style of boondocking that makes several days in the clouds and rain possible.
1/1/21 Retirement Life Begins!
Chocolate Subie Ascent, Silver T@B CS-S, 4 spoked wheels, 2 ol' legs - we're good!
Oregon <--everywhere--> Hawai'i otherwise
Wiring before Smart Shunt
Wiring with Smart Shunt
Battery settings on Smart Shunt
Smart Shunt readout
Smart Solar readout
Also, even with the Jensen display off, it consumes a certain amount of parasitic power, as do any USB ports and a few other things. You may want to search the forum for ways people have dealt with that. I ended up adding a kill switch to my Jensen (with thanks to the lovely folks here who walked me through my very first attempt at dealing with wiring.)
I’m not familiar enough with the SmartShunt to pass an opinion on whether it’s working correctly, but I can say that we have several long time members here who’ve found that to do any boondocking with the current 320 models, upgrades to both the battery capacity and solar panels were necessary. The group 24 battery would be the first thing I’d replace, either with 2 6v AGM golf cart batteries or with a lithium (or two). You really need more capacity than that group 24 could ever provide. Then I’d look at getting a portable solar suitcase with controller to augment what you already have. Given that you’re in the northwest, 200 watts would be the minimum I’d consider…I just added a 200 watt portable myself a couple of weeks ago because the 100 watt suitcase I used previously simply wasn’t enough for this region.
To be clear this experience was without television or entertainment center, no inverter, 3 way fridge and spending as little time inside as possible, it can be done
We normally camp with hook-ups. Texas has different issues while camping. No air conditioning means you can only camp a few months per year. We do take an ice chest when we need to be off the grid for a while of for drinks.
My CS is a 2018. We don't have the installed solar. A portable panel for 'winter' camping is in out buy list. ; )
"Just Enough"
Don't feel bad, I think you did great for your first boondocking trip. We just got back from our first one at a sunny National Forest Campground near Tucson. No trees, no clouds. I learned that I need to either point the trailer southwest or get more panels. After three days with using the Alde only a few hours in the early morning, my battery voltage down to 11.99V or "Fair" after 3 nights. I was not getting enough sun to keep the battery charged. (Boondock Solar with 100 Amp Hour AGM).
Your experiences and the responses are helping me figure out what to do better next time. Better Refer management is definingly needed. I should have shut the thing off the last night when it was half empty.
Happy trails,
K&C
2020 F150 2.7l V6 Turbo
Tucson, Arizona
As for me, I want 5-6 days of problem-free boondocking, with no concern needed for conservation of power usage, which means I needed 200AH lithium batteries. I still want to get a 100 or 200 watt suitcase solar panel because I'll likely be camping in shade most of the time and want a way to keep the battery depletion to under 10% per day (my last camping trip I used about 13% per day and the solar panel on the roof was shaded so I didn't get much from it; having a solar suitcase would allow me to potentially top it off daily or at least get the depletion within that 10% per day mark).
We went three nights and days, on battery with afternoon (lightly shaded) sun hitting the solar panels, and the battery only used around 30 amps or so, and was recharged 100% by the end of the day. We have the first generation compressor fridge, and he new Danforth Compressor fridge is even better at using power, getting more bang per amp.
A 100 amp lead acid battery is what I would call a minimal size battery, OK for occasional use, but you only have 50 useable amps. A 150 amp AGM or 100 amp lithium would be the minimum size battery for the TaB320 for boondocking over a three day weekend. Longer off grid trips without good sun, will require a bigger battery. So the size and type of battery you need depends on how and where you are going to camp.
Obviously that doesn't fix the OP's problem of running out of power but the solution doesn't have to be overkill.
@VictoriaP We did travel down to Yosemite and lucked out on the sunny window from our first day of travel and on. We did end up with a few scattered clouds on the last day, but that’s when we actually had our first night of not losing power. However, yes, I am seeing from the responses here that our 100W panel alone won’t help us boondock.
I remember seeing a post about a Jensen kill switch and will look that up! Thank you for that reminder. And yes, upgrading our battery seems to our first step, and the portable solar is now on our Christmas list.
Thank you @Denny16 and @pthomas745. We are headed to HD today and working on the settings!
Mahalo @Mikerly for the search term. Our mouths are agape from how much parasitic amps are used.
Mahalo @K_C_915 for sharing. This FS site we stayed at would not have allowed for us to turn our trailer to optimize the solar panels. We have only stayed at one site where we could have, so I’m being sold on the idea of the suitcase rather than upgrading the stock panels.
@DenverJaguar Yep, I am learning that we are in the minority both in the clamshell model preference as well as amount of boondocking we want to do. Admittedly, we enjoy the hookups if the sites are tucked into nature. But we are also discovering we cannot find those places without booking way ahead of time. We want to feel a little freer to explore without worrying about where to find ice, clouds, too many trees, etc. Please update us on your experience after you get the suitcase.
