Sometimes just doing a minor fix or upgrade can give a person a great feeling of accomplishment. What are some of the little things you've all done to make your T@B more enjoyable.
On our last trip my wife ended up hitting the USB cable I had running from the outlet next to the CO detector up the wall to the firestick plugged into the back of the TV. This of course caused the firestick to reboot.
When I got home, I fished the USB cable down thru the wall behind the TV. I plugged an extension cord into the A/C outlet feeding the ALDE and ran it up to the wall where the cable came out on the floor and hooked up the USB power adapter. No more getting tangled in the wiring!
Tampa FL
2 ·
Expect for me No Modification has been a ' little thing ' as in seems some unexpected issue is always included - - - be it parts, tools, or my skill set - - -
That said, I look forward to hearing what others feel were ' little thing ' mods!
1) Installed a key hook just inside the door on the left (opposite side of instrument panel) for TV keys and T@b keys.
2) installed another hook on the lower cabinet near the sink to hang dish towel.
3) installed removable "ultimate jack"
4) switched out clunky safety chains with self coiling cables.
5) switched out the sewer cap with the kind with the threaded hose outlet so I can do a partial gray tank dump into a portable container without using sewer hose
Bigger things: installed BMV-712 Blutooth battery monitor. Installed smart converter with boost mode, split off the bed AC vent and added another vent in wall board below fridge (before they put a cubby there) that vent blew so hard I felt like a dog with its head out the window of a moving car.
Latter I went crazy and removed the aluminum shower curtain “hook” that always jabs me when sitting on the lou.
Tampa FL
San Diego, CA
www.airbossone.com
So I installed 2 rods over each burner that filled in the gap, making the coffee pot balancing act a thing of the past. A little bit of file work on the rods was necessary to lower the level of the new rods to the existing grate. The rods are held in place by some fine wire on the ends. It seems to be holding up quite well.
2017 F-150
Coeur d'Alene, Idaho
2017 F-150
Tampa FL
nüCamp: 2019 T@B 400 Boondock Lite
1) Changed battery to larger AGM and moved inside (more secure and lightened the tongue).
2) Put all the parasitic draws on the battery on a switch panel (ceiling LEDs, USB ports, TV, radio, etc.) and added a Blue-Ray player and a voltmeter for the battery.
3) Changed the low fixed faucet to a higher swivel faucet.
4) Added a table bracket by the door so the table can be used as more counter space and a headboard at night.
5) Changed the outside light to red and added red LED strips with a lower switch by the door for better night vision to use when I'm using the telescope and camping at astronomy campgrounds.
6) Added a fixed telescoping omnidirectional TV antenna (no holes in the roof) so there's no set up to use the TV when in parking lots or rest areas.
7) Added a bathroom fan in the outside bathroom wall (drilling a large hole in the side of your new camper is not for the weak hearted).
8) Added a Garmin backup camera to the T@B that uses my Garmin GPS as the display.
More: https://solocanoes.com/camper.htm
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
TV 2025 Telluride X Type
