Hello wonderful helpers on this forum,
With the cold weather setting in where I live, I'm back to battery questions. I have a lead acid battery (I think? It's the kind that has to be "watered") and again it drained overnight with the Alde heater set at about 60 degrees. I last put water in it maybe a month ago. I'm tired of this battery problem, and think I'll go buy an AGM today. I don't know if the problem was not enough water in that thing, or what; maybe some chilly nights drained it, too.
What is required to keep an AGM charged when boondocking? I have factory-installed solar on my roof. I've gotten pretty good, I think, with conserving power over the summer/fall; basically kept my 3-way fridge going all the time and that was the only 24/7 draw. Will freezing temps drain an AGM? Will the solar do a better job of charging an AGM compared to lead acid? Does an AGM have to be taken inside the house in the winter?
Please share your thoughts, and thanks in advance for reading my post.
2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
0 ·
SW Colorado
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
Everyone is correct, run your fridge on propane. It works best on gas. It will eat batteries on electric power. If it's not running correctly on on gas, you have spiders, soot in the chimney or it's been stored un-level which causes the ammonia to not flow right.
"Just Enough"
2019 320 Boondock Edge - Sold Jan 2022
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
Consider that the battery in your truck sees the same temps.
It is currently 7% off. They are advertising 15% cyber week (starting 11/22).
2019 Toyota Tacoma
Asheville, NC
A group 31 refers to the battery's measurements. If a group 31 wet cell fits in the standard plastic tub, a group 31 AGM should fit as well. Good luck!
Oh, and btw, our flooded wet cell sits out all winter, but it is plugged in to shore power. We check it, and fill it if necessary as we cover it. Usually sits 5 or more months like that, until the spring when we uncover and check it again. We have stored it once through the winter unplugged. In November, with no load, battery read 12.7 with a multi-meter. In April, still with no load, it read 12.6. Battery switch was in the off position, stored covered with no solar or additional charger and we had nearly 2 weeks of nearly -10°F weather that year. A well charged, healthy battery, wet cell or AGM can sit for months in a static condition without much loss of charge.
You can see more details here. The steel frame I made was probably overkill--you could accomplish the same thing with just a simple piece of wood to extend and angle the platform.
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
