In another topic, I had posted links to a couple of videos that introduced the concept of installing an anode rod (like those used in water heaters) inside the glycol expansion tank, in order to help prevent galvanic corrosion in the Alde system.  Here's the link to those..
While this is acknowledged to be an experimental idea, I thought it sounded like it has the "potential" to help with corrosion in the Alde heating system, so decided to give it a try, since I'm already familiar with doing this for our home water heater.
which I cut with a hack saw to fit inside the tank.
The photo below shows how I prepared the anode rod to fit inside the threaded cap of the glycol tank.  I saved the plastic disk top inside the threaded part of the cap & replaced it with a disk cut from a sturdy plastic bottle.
Because it is difficult to solder a wire onto a flat surface (which I roughed up with coarse sandpaper) and get a strong joint, I also mixed up some JB Weld epoxy glue and added that on top fo some extra strength..
I ran the 18g wire into the corner to the floor..
then through the rear storage compartment inside a piece of narrow plastic conduit to keep it from getting tangled up with other stuff..
Then I ran it through the same opening as the Alde hoses and into the Alde compartment, again inside a piece of stick-on plastic conduit..
Using another circular wire connector soldered to the end, I fastened it to one of the screws holding the gas line fitting to the Alde chassis..
And that's it!
If you do this, and have a voltmeter, before you hook it up, I'd be curious to hear how much voltage you measure between the end of this wire and the the Alde screw.  I'm wondering now whether the reading might be more steady with the glycol circulating.
By the way, did you know that in the past, T@Bs used to have a water heater anode rod?  See the Tab manual link given here by Wanderoo..
I assume this was an anode in the hot water tank itself (and probably not an Alde), as in a home water heater, and not the glycol tank like we're talking about here.  Still, it does make me wonder why the Alde never had one.
Happy Turkey day!
Any further thoughts?
I just watched the video series you mentioned. The more recent comments--including yours--were also informative.
Engineer Mark (the guy who makes the videos) doesn't directly address the crevice corrosion on the convector stubs. He mentions in the first video that some owners have reported corrosion in these locations, but never explicitly reveals the state of his own T@B.
In the comments--and in the second video--he touches on the different types of corrosion, implying that what is going on at the convectors is acidic corrosion and will not be mitigated by the anode rod (which combats galvanic corrosion). He suggests that regular changing of the glycol (to maintain the pH) is the key to preventing this, but now we are back where we started... owners who have tested their glycol have found it retains its high pH (i.e., it is NOT acidic) even if neglected for some time.
My guess--and it's not much more than that--is that the convector problem is a type of acidic corrosion stemming from a combination of fluid stagnating between the hoses and aluminum convectors, that fluid drying/crystallizing (and possibly becoming acidic at the point of contact), and the direct contact eating away at the metal over time. If that is the case, then I suspect properly sealing the hose-convector connections is the best strategy for this particular problem. Given that Alde appears to offer a sealant for just such a purpose adds credence to this idea.
This is not to say the anode won't possibly protect against other more elusive galvanic corrosion issues inside the boiler itself, but I suspect it is another red herring in this case. The same may be true for often discussed concerns about properly grounding the Alde--while this may combat the electrical corrosion Mark also mentions in passing in the second video, it may not solve the convector corrosion issue either.
Just some food for thought while we await food for bellies. Happy T-Day, all!
managed by VE Smart Network
St Catharines, ON
High pH isn't good either. It is at least as corrosive as low pH (acidic) on aluminum.
Numerous studies in literature show that the protective aluminum oxide film (which forms when immersed in air or in an aqueous solution) that is stable near a neutral pH range is dissolved away when pH readings are outside that range - both lower and higher. And corrosion rates are shown to be accelerated by immersion time, temperature, and to some extent, salinity.
Since the new Rhomar is at a pH nearer 7.0 - 8.0 from the get-go, as @BrianZ and others surmised, I too believe the switch was needed because the Century was seen as ineffective on aluminum under certain conditions, both initially and especially when the buffers/surfactants/inhibitors were expended. It may not entirely be the root cause of these failures, but it sure is a factor. Oxygen in the system, under-deposit-attack, surface irregularities may also contribute.
Aluminum being what it is, is already prone to metal loss, even in the best of conditions. The stagnant areas are an easy mark for metal loss, because there's a lot going on there to contribute to the corrosion process. The rest of the system at least has the advantages of being a large "anode" with more surface area that hopefully spreads out the pitting if corrosion is inclined to happen there. Plus it sees moving fluid with hopefully constant corrosion inhibitor replenishment while in use.
The fact that some pretty new systems are showing signs of this corrosion is something Alde/Truma needs to explain, because I'm pretty sure they are aware of the reasons.
SW Montana USA
Thanks for reminding us, @BridgerSunset, that corrosion in a system is also a balance depending upon the total surface areas that come into play.
If I see significant anode corrosion before the next glycol exchange is due, I would remove it & try to clean with a brush & possibly drain a few ounces to remove any sediment & top off.
https://youtu.be/HcUqcYii7XQ
TV 2025 Telluride X Type
I was especially curious about his statement..
"I expect to find that the other metallic
OK, but how will he find that?
PS: Unfortunately, I don't think the heating element is protected by the anode rod, if it doesn't have electrical contact with the Alde cabinet.
I had posted the results of my testing with a magnesium anode this past week in the thread about corrosion earlier today. Based on the tripling of the voltage measured at the convector under the floor of the shower (TAB 400 BDL), and the tripling of the current flow .2 micro amps VS .7 micro amps. with the anode connected to ground, I decided that adding an anode was not the correct decision for me, but I respect the decisions and opinions of others to do so.
Airstream makes no mention of an anode in their bulletin. I suspect there are way more Alde systems installed in the Airstream population than NuCamp, but I could be wrong.
I think most of the issue goes back to the 8-gauge ground wiring that Airstream specifically says to replace with 6-gauge. This is further driven (my opinion) by how the camper is being used, IE shore power VS boondocking. And by adding the auxiliary ground wire to the boiler case just ensures that there is a path to ground for the glycol, even though it has a very high resistance.
Brad
Concord, NC
Thanks, Brad, I saw that, and plan to add my ground measurements there, based on your previous suggestions, plus a few thoughts on your anode report. I'm still trying to catch up on the writing & posting part of what I've found, but been busy with taxes & stuff lately. How are you measuring microamps?
I used a DMM that has a micro amp scale, how accurate is a question that I can't answer. But I can easily see the measured voltage between the under-bath convector go from 256 MV to 750 MV with the anode connected to ground VS not connected. To me, this indicates that a higher number of electrons are moving from the convector into the glycol, which is the exact opposite that I had thought or wanted.
Brad
Concord, NC
I think the answer may be to ground the convectors also, as some have done. The anode rod in the glycol tank can only protect what it's grounded to (or metal shared in common plus in the glycol/ electrolyte), and in the linked video by Mark he clearly (& correctly) says it won't protect the convectors without a common ground with the anode, just internal Alde parts. So it wasn't intended to protect convectors.
the Alde was not in operation.
