It will fill from either, but you have to hold the valve open for the water to flow. It doesn't refill automatically. Also, as you are aware, you only want to add a little bit of water to the bowl.
Brad
2020 400 BDL aka "Boonie" 2022 Black Series HQ19 aka "Cricket" 2021 F-250 Tremor with PSD aka "Big Blue" Concord, NC
@cthruglass Generally, the freshwater tank can be empty and the pump turned off when you are hooked up to city water.
You don't mention what model/year T@B you have. Perhaps you can add that to your signature file for future posts. It will help the appropriate folks answer specific questions.
@cthruglass - a hook up to city water supplies all your water needs (including flushing) at the time, so, there is no reason to have/use water from your fresh tank. Use your fresh water tank and pump to supply all water needs when NOT hooked up to city water. Welcome to the TaB family!
Maybe something is different with the toilets in 2021s (aren't these cassette toilets?) but this just doesn't jive with the standard T@B plumbing layout.
The city water connection and the FW tank/pump combo are just two different supplies to the same distribution lines. Everything should work the same regardless of which supply you are using.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
Interesting...I'm curious as to why that is. I was under the impression that the toilet (like faucets) are purely mechanical. Which part of the toilet requires power?
2022 T@B 320S Boondock 2021 Toyota RAV4 TRD Off Road Ottawa, Ontario, Canada Instagram: new.t@bventure
Cassette toilets can also have their own fresh water/(chemical mixed in) flushing tank, so the toilet is not always plumbed to the trailer water supply. Not sure how nüCamp set the cassette toilet up. Some are connected to the trailer water supply. cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
Brad
Concord, NC
2019 320 Boondock Edge - Sold Jan 2022
