We have a T@B 400 Boondock on order with delivery hopefully in March or April. Neither of our cars have enough towing capacity so we also need to get a tow vehicle. We’re interested in your thoughts and experience as we sort through our choices. Our general criteria, in order of importance, are:
1 - Reliable: We plan to travel far from home and sometimes far from towns so the last thing we want is any sort of mechanical problem.
2 - Roomy and convenient: We know storage in the trailer is limited so we expect to carry a fair bit of stuff in the tow vehicle and that should be easy to pack and unpack.
3 - All-wheel drive: We don’t expect to go 4-wheeling but we do want to sometimes get back and away from main roads with the trailer, and like reliability the last thing we want is getting stuck.
4 - Comfortable and quiet: We’ll be spending many hours in the tow vehicle so it should be easy and pleasant to drive.
5 - Mileage: All else considered, higher is of course better.
What other factors might we consider? Any comments on our priorities?
With what I’ve listed right now our top choice is a Toyota Highlander. Any comments on that vehicle? What other vehicles do you recommend we consider?
Thanks!
Bubbles - 2022 T@B 400 Boondock
Tug - 2021 F-150 4x4 Hybrid
0 ·
2017 Highlander Limited
2020 Audi SQ5
Jeff & Amy
Brad
Concord, NC
I guess I should qualify my Tundra love. As I said I bought it new in 2003 and didn't have anything to tow behind it until a year ago. But I've used my truck to haul a lot of tools over the years as well as get me to remote places to camp, canoe and backpack so for me it was a no brainer when the T@b showed up. If I wasn't a truck guy and was getting a T@b I might genuinely be looking at a sturdy SUV for a TV.
It is a 2.8 litre engine. Superb fuel milage. High torque at low RPM makes it great for hauling.
I am a calm, steady driver. If I craved breathtaking acceleration, this engine would not satisfy me.
As it is, I’m entirely satisfied with this rig. I did install add-a-leafs to the rear suspension and I use a weight distributing, sway inhibiting hitch.
Some of the factors in choosing a tow vehicle is how you plan to use your camper. I live in S Carolina but like to boondock in the west, I often do 700 mile days and have done 900. I have towed my 400 with a Honda Ridgeline (V6), AWD. The Ridgeline was capable of towing the 400 but in some conditions it struggled. The 6 speed did a lot of shifting, even on a slight overpass it would shift down. It needed a WDH, and it moved around a bit in high winds and when being passed by semi’s. For me the Highlander would not cut it because of its marginal power and short wheel base. I now have Ram 1500 (V8), 4x4, 8 speed, for me it has worked great. When driving the 1500 through the Colorado mountains I still feel the camper, I think it would be a torture test for a Highlander.
I did not mean to disparage the Highlander, I was trying to convey to the OP that a mid size SUV maybe marginal for towing the 400 in certain conditions. I would not suggest that a ½ ton pickup is needed but I do find towing with a ½ ton comfortable and reduces stress on long travel days particularly with bad weather. I like camping in the mountains and sometimes have long travel days so that is why I traded the Ridgeline for the RAM but if not for towing the Ridgeline is generally a better vehicle.
Ford has done a great job with the F150. I love it.
Whatever you end up doing, get more towing and weight capacity than you need. You will never be sorry.
I haven't read all the posts, but make sure you understand what towing capacity and Gross Vehicle Weight Rating mean and ensure they will meet the requirements for your 400 and the cargo you plan on bringig with margin.
2020 F150 2.7l V6 Turbo
Tucson, Arizona
Payload Capacity is the "Gross Vehicle Weight Rating minus the curb weight of the vehicle as equipped"; which is easier to use than GVW.
Example, you compare 2 vehicles that have an 8500 Pound Gross Vehicle weight rating, the "Payload Capacity" can be vastly different due to the configuration of the vehicle. An example would be 2 F-150 pickups that have the exact GVW but are equipped completely different (IE 2 WD VS 4 WD). The Payload Capacity will reflect this and is simpler to use.
It is also imperative to point out that the tongue weight of the trailer being towed MUST be subtracted from that same "Payload Capacity".
Brad
Concord, NC
In the case of a pickup type truck, most of the weight loaded in the bed and the trailer tongue weight is over the rear axle, which has its own weight load limit.
Just food for thought...
San Diego, CA
www.airbossone.com
2020 Audi SQ5
https://youtube.com/c/IDoCarsalldaylong
He has torn down two Ford Eco-boost V6 engines. I wouldn't own one after watching both of those, if the water pump fails it is a very expensive repair even if the motor isn't trashed, a totally bad design. I don't know if the water pump location has changed on newer versions or not, but in both of the teardowns I watched, it is inside the engine timing cover, a failure dumps coolant into the engine internals.
I would say a large majority of failures of all engines are on the owner due to lack of oil changes or other abuse, however I have also seen overly complex designs or bad designs that basically render the engine trash when they fail.
I have learned alot, mostly about what I wouldn't own. Keep that oil full and fresh too!
If you only keep a vehicle 36 months or under 50k mikes it probably doesn't matter, but if you do, then what you buy mechanically is as important as the seats and the sound system or whatever else you think is important.
Towed by a white 2017 4x4 Nissan Titan XD Pro-4X, 5.0L Diesel, aka Prometheus
