Dan, what do the last two pictures represent? Is that damage as the result of overloading a roof rack? I've been routinely carrying +/- 125lbs on my homemade rack. Don't like the thought that it could be failing under the shell where I can't see it.DanWeitzel said:This is what your roof rack is attached to in the trailer structure.
The stock Yakima rack on the Boondock has a 70 lb limit. I wouldn’t exceed that amount.AnOldUR said:Dan, what do the last two pictures represent? Is that damage as the result of overloading a roof rack? I've been routinely carrying +/- 125lbs on my homemade rack. Don't like the thought that it could be failing under the shell where I can't see it.DanWeitzel said:This is what your roof rack is attached to in the trailer structure.
VictoriaP said:The stock Yakima rack on the Boondock has a 70 lb limit. I wouldn’t exceed that amount.
No opinion on “better or worse”, but if the limit on the factory mount is 70, we know without question the roof is designed to support at least 70 in the location where nuCamp mounts the Yakima. What we don’t know if it can sustain more weight in that location, or whether or not your homemade solution with different mounting points on a different part of the roof can handle almost twice that weight without damaging the structure in ways you cannot see until it’s too late.AnOldUR said:VictoriaP said:The stock Yakima rack on the Boondock has a 70 lb limit. I wouldn’t exceed that amount.I don't know if it's for better or worse, but my rack is not a Yakima. It's made from spare parts I had in the shop and a Harbor Freight hitch basket. What makes me nervous is that the @DanWeitzel picture looks like it split clean across. I can't imagine a failure that would cause that. It does appear to be where a rack mounting screw went through one wall and the wire routing hole probably didn't help. I still don't see there being enough flex to cause that type of break. More details from Dan would be helpful.Lots of mile on this with no signs of problems, but ....
My understanding is that the “cage” is intended as nothing more than a lightweight (mostly decorative) brush guard. NuCamp has stated it cannot be used as a step to reach the Yakima rack, but I haven’t seen a specific weight limit for it. I would suggest you contact them regarding your intended use to confirm before putting any weight on it at all. My guess is that “towel rack” really is the best use for that cage.markbless said:I agree with your logic and conservative approach, VictoriaP. Still leaves possibility of one bike on rack across Yakima + aluminum cage.
Dual Hitch Extender
https://www.harborfreight.com/dual-hitch-extender-69881.html
I am going to look into this concept myself and weld something up when i reweld our tray.
Also beware... Our 2021 tab 320 front aluminum tray came attached with only two 1/4 inch bolts through the wimpy c channnel trailer frame, and two #14 self sheet metal screws. I redrilled frame for four 3/8 grade 5 bilts, plate washers to spread torque, and nylok insert nuts. One good bump could have sheared the screws and pivoted tray and contents upwards torquing the propane line.
Also discovered you can jacknife backing up and crunch front of tray with bumper on a foggy night. Extended tongue a necessity!
Out tacoma pickup tailgate height when lowered would have hit the original trailer jack. Replacing jack with side mounted swing down type required fabricating a mounting/shim plate against c channel frame and remounting tray 3/4 inch higher for jack clearance
Maybe american truck tailgates clear but i tthink the factory tongue us way too short.
(+ Frame built with S&S couplers)
For those who are new to towing and may not know: Using a hitch extender cuts your tongue weight limit in half. Since most vehicles towing Tabs have between 350 and 500 lb tongue weight limits, a 50% decrease typically puts you below the tongue weight of the loaded trailer before you even load a bike on there. In other words, it’s not a good idea to use one with a Tab unless you have a vehicle with a tongue weight limit of 700 lbs or more, and have an accurate tongue weight on your loaded trailer so you can be sure you aren’t exceeding the new lower limit (a lot of people have no idea how much their trailer tongue weighs once they load up their rig).Maxcamp8 said:
Not endorsing, thete are hitch extenders that might keep the bike with the vehicle while extending trailer tongue back for clearance. Beware of crappy welds hidden under black paint however.Dual Hitch Extender
I tow our 2018 400 with a 2019 Ridgeline. Works well, have been across country once and about to go again. Climbed through the Big Horn National Monument, which is pretty challenging - no problem! We have the 6 speed auto trans, the new ones use a 9 speed with paddle shifters, supposed to be even better. Turn off Eco mode when towing, it is a much better experience, you actually accelerate immediately when you press the gas instead of sort of spooling up like a turbo. Plus, cruise control works much better, which is good because I get much better MPG when using it.DirtyRanger said:We're in the same position and have decided to get a pickup truck as a TV instead. I know that seems drastic, but I think it is the best option. The Honda Ridgeline is a fantastic little truck that drives like a car as it is basically a Pilot with a bed instead of a trunk.
