I purchased a Baja 900/700W generator solely for the purpose of battery charging when solar isn't enough to get the job done. The generator came today. It starts and runs well and the noise level is not too bad, but I'm having problems getting it to work with my 320S T@B. My on-board Progressive Industries EMS-HW30C is displaying an E2 error, open ground. Appliances plugged directly into the generator work fine. Does anyone have experience with this or other generators while using an EMS?
0 ·
Neutral plug: https://www.amazon.com/Southwire-Company-LLC-44400-Generator/dp/B07F4R7BDL
Reference article with more details: https://www.rvtravel.com/rv-electricity-jam-oper-ground-generator/
If hardwired EMSz there should be a bypass switch and if course if portable, just don't use it.
Pulsar 2,200W Portable Dual Fuel Quiet Inverter Generator with USB Outlet & Parallel Capability, CARB Compliant, PG2200BiS https://www.amazon.com/dp/B07J5HD8L9/ref=cm_sw_r_awdo_navT_g_7AGTEFPRY1BZ6092PSZZ
2019 320 Boondock Edge - Sold Jan 2022
Brad
Concord, NC
Example: on our 2020 400 BDL with the WFCO Converter, I could barely get 20 Amps no matter how dead the batteries were. This is caused by the 3 factors I mentioned above which creates resistance in the charging circuit and the Converter selecting the inappropriate mode of charging.
Brad
P.S. Happy birthday to your wife!
Concord, NC
Example, in our 2020 400 BDL with the OEM AGM Batteries, it would take 24 to 36 hours to fully charge them. This is caused by the resistance in the charging circuit wiring, which restricts the amperage flow while raising the voltage at the same time. This causes the WFCO to move to the Absorption Rate of Charge instead of using the Bulk Mode.
By installing a PD9260CV under the bed (with a pendant), I could charge the AGM Batteries in less than 3 hours if they were nearly dead. I continued to use the PD9260CV after installing 2 x 100 Ah BB Lithium. However, when I added another 200 Ah, I changed the Converter again to a PD9160ALV. I changed it because the forced "Boost Mode" on the PD9260CV times out after 4 hours. 4 Hours may not be enough time to fully charge 400 Ah and I don't like to babysit things.
NOTE: If you typically camp with shore power available, none of this really matters for your use.
Brad
Concord, NC
Which is to say I’m not sure 30 minutes rest either after charging or after usage is giving you any useful data. The battery needs longer to rest if you’re after accurate results.
Kind of exasperating, really. I’ll be very interested to see what happens with both your experiments and mine.
If you look at the manual for the MPPT75/15 Solar Charge Controller, it clearly states as follows under section 3.3
● The controller will operate only if the PV voltage exceeds battery voltage (Vbat).
● PV voltage must exceed Vbat + 5V for the controller to start. Thereafter minimum PV voltage is Vbat + 1V.
The answer is NO, it will not work. It will not damage anything, but it will never charge either because you will not exceed the battery voltage by 5 volts for the MPPT to turn on.
As far as advantages of using a stand-alone charger VS the OEM converter, it comes back to goals. Ask yourself these questions to help guide you to the best solution for your needs.
How do you typically camp, with or without shore power?
Do you have a compressor 12-volt refrigerator or a 3-way refrigerator?
How many Ah of batteries do you have, are they SLA, AGM, or Lithium?
Does your TV charge the batteries as you drive?
If so, how many amps are going to the camper?
If you camp without shore power, how long do you want to run your generator to charge the batteries?
How many days at a time do you typically camp without shore power?
How many days can you go without charging your batteries?
Do you have a Smart Shunt (BMV-712 or similar)?
Brad
Concord, NC
About a 50/50 mix with dry camping 3+ days at a time.
Compressor 12V that uses about 30Ah per day. That along with my other 12V accessories probably get to 40Ah per day tops.
Two 125Ah AGM's
It does, but I'm not sure how many amps the Jeep provides.
Given the choice, I don't want to run it at all. Purchased it for when solar won't keep up. My thought was that going directly to the battery with a charger (not using the T@B's converter) might be faster?
Could be one day to a week or more. (Have an Alaska trip planned.) Trying to be prepared for any situation.
No more than three when solar isn't available.
However, let's do some quick calculations based on your numbers.
1. If you are truly using 40 Ah per 24 hours, to recover that with a 5 Amp charger will take 8 hours if there was no further draw. However, you are going to continue to power all things 12 VDC at the rate of 1.66 Amps per hour (40 Amps divided by 24) the net charge rate becomes 3.44 Amps, and it would take more than 12 hours with a 5 Amp charger to recover 1 day (40 Ah) of use.
2. How does this compare to the output of the 35 Amp converter (I suspect that is what is in your WFCO), I can't answer because I am not positive (but I am pretty sure) that the OEM never goes into the Bulk Mode due to the resistance. Instead, it is likely going directly to the Absorption mode which is why it takes 24 to 36 hours to fully charge depleted batteries. It would take a smart shunt or clamp on amp meter to determine actual output of the OEM converter, which of course will be directly relate to SOC at the time.
There is an advantage to the OEM converter beyond the charge rate, and that is that the converter will supply the 12 VDC needs in place of the batteries when it is powered up. Also, if your refrigerator is dual voltage (12 VDC or 120 VAC), the refrigerator will switch to 120 VAC. When it switches to 120 VAC, you are already ahead of the game, regardless of the output of the OEM converter because you are no longer operating the refrigerator on 12 VDC.
Hope this helps!
Brad
Concord, NC
