Lithium or AGM Battery Mounted Inside a 320 Cabin?
2»
    Thanks @jkjenn.  I will check out your video.
  • tomtektomtek Member Posts: 48
    I upgraded to 280aH DIY Grade B Lithium Cells I assembled along with relocated battery in the cabin passenger side wheel well storage of 2021 CS-S.   I upgraded the converter to a PD4060(LI) and have upgraded wiring to handle the higher charge currents. Other notes is the addition of a 1200 watt inverter and automatic cut over switch for inverter.   Its been a major electrical overhaul but am extremely pleased with the result and it's possible I may add another 280aH of Lithium.  I watched @jkjenn video before my work and got a lot of great info from it and was able to make a more informed choice of my conversion.   Thanks @jkjenn great video with precise reasoning behind your decisions.   I have a few other electrical changes I am happy to share if there is a request.
    2009 Dutchman TQ - Sold
    2021 CS-S - Enjoying the new layout
    2011 Outback 3.6r
    Sharing is caring @tomtek  :)
    Start a new discussion, so we don't have to wade through all of this one to see your ideas. I find it hard to later look back at concepts when they're hidden within a discussion of a different title.
    2019 320 Boondock Edge
     - Sold Jan 2022
    Nice job Bayliss.
    @Bayliss Here is a VERY limited view of the driver side construction that I believe shows a thin, metal plate in the area behind the wheel.  Probably just to allow them to add in electrical and plumbing before the side wall is added.
    edited February 2022
    Thanks for the photo, @Sharon_is_SAM I don't believe I have seen that particular photo previously, but it does indeed show a metal plate at that location, albeit in a later year model 320 S.
  • ReenieGReenieG Member Posts: 283
    Cherokee said:
    Cool solution - storage space is always a rob Peter to pay Paul proposition.
    We are lucky that we can get by with two golf cart 6v batteries in series - thanks mostly to portable solar and California sunshine.
    @Cherokee do you find these work better than one regular 12v deep cycle? And do they both fit in the standard group 27 size battery box in your tub?
    edited June 2025
    Over time, I have made some updates to the components and wiring within the electrical compartment of my 2019 320 S Boondock Lite, so I am posting the below wiring diagram and photos in the event they are of value to someone else.
    My previous upgrade of the electrical compartment (below the driver's side bench) involved removing the OEM 12V battery from the aluminum tub and upgrading to a Battle Born 100 Ah LiFePO4 battery, which I installed in the electrical compartment along with the battery disconnect switch.  Regarding the below wiring diagram, I confirmed that my 2025 Toyota Tundra 4x4 Crew Cab has an isolation relay, so the 12V+ wire from the truck via the 7-way power cable is wired so that power to the trailer is provided when the truck ignition is "on", but disconnected (and not back-feeding to the truck battery) when the ignition is off, even if the 7-way cable remains connected.
    Since February 2022 (see previous posts above), I have added a Victron MPPT 75/15 Solar Controller, Renogy 220W Solar Suitcase, Progressive Dynamics 4135K Power Center/Converter, DC Terminal Block (for better DC wire organization), positive "+" and "-" busbars, and a "Tire Tracker" TT-600 TPMS Signal Booster to monitor the trailer tires air pressure.  Those changes were all done some time ago, but I never got around to preparing a wiring diagram.  I have now completed the diagram, so it seems like a good time to post the information.
    UPDATE (06-15-2025): After re-reading this entire discussion thread, I recall that I had been seeking assistance on how to get power to the battery from its original location in the exterior aluminum tub, to the interior driver's side bench electrical connections compartment.  Additionally, I wanted to ensure that 12V power was available to the electric brakes.  Both turned out to be very simple, because the "+" and "-" wires from the Junction Box had already been routed to the electrical compartment (and on to the converter) during construction of the trailer by nüCamp.  Again, if it is of value to anyone thinking of relocating their battery in an earlier model year T@B, I prepared additional diagrams to separately depict/highlight the paths of the 12V+ charge line to the trailer battery, and the path of power provided by the trailer battery to the electric brakes and interconnected breakaway switch (see below.)  An expanded view of the Junction Box ("J-Box") wiring is included in my November 2021 post earlier in this discussion thread.
    I've been Boondocking for years with two 6v AGM's , a NorCold 180.3 (3-way) and a 95w Zamp solar suitcase.  Though I have to occasionally read a thermometer and make an adjustment, this combination is a great set -up for camping off-grid for prolong periods. One propane tank and the batteries:
    California, USA
  • deepsea5deepsea5 Member Posts: 7
    Good morning Bayliss,
    Thank you very much for your detailed explanation of how you relocated the battery.  My wife and I recently purchased a 2021Tab 320 Boondock and plan to relocate the battery in the same place you chose.  The Newitpower 300 AH battery I ordered just arrived and it will be able to be "shoehorned" into the same location as your Battleborn.  Hoping to start the conversion in a couple weeks or so, depending on weather and work.  Looking forward to retirment and relocation to the Tucson AZ area in 2026!
    2021 Tab 320S Boondock.  2016 Toyota Tundra TV.
    Sabattus, ME & eventually Tucson, AZ
