We are doing a break-in trip in our Tab 320S and hooked up in an RV park to city water. I can’t find a solution today by searching the forum but know I’ve seen someone with a similar problem but can’t find it. I’m sorry if I have to repeat a previous problem/question.
On City water I connected the hose to Nautilus with both red and blue levers horizontal. Did get water inside but had cold water coming out of the tube beside driver’s side rear stabilizer. And after a bit had a water hammer effect so turned off City water. Fiddled with nautilus controls to no avail. I did turn the City water faucet down and now it’s a drip, drip.Any suggestions? We’d like to go on from Wichita KS to South Dakota if we can work the bugs out.
Suggest you recheck your Natutilus Levers . . .
While you did not comment on the White or Green Handle/lever
If it were me . . I'd turn-off everything and go for a walk.
On returning and starting to turn everything back-on you might find an ' of course ' user error
Here's what I found, I loose fitting to shower faucet and I'll spray water all over (I had the water turned off and pressure released.). There is either some sort of impediment in the lines both hot and clod leading from the PEX lines to the line ex on the shower faucet. It isn't the PEX, It's the mesh covered lines or possibly the faucet itself and that is a real possibility!
I'm going to see if I can take the faucet apart and look at the valve.
Hope your trip proceeds without further issues:)
