Hello:
Would someone kindly take me through the entire process of checking ALL seals and other maintenance checks (but mostly seals) please? Pictures are great, especially with arrows, boxes, etc., highlighting the areas to be checked. There are drips on the ground at the back of the trailer by the brake lights (plus it rained last night). Also, how do I post pictures to show problems please? 2018 320s
Many, many thanks.
0 ·
1. Place your cursor in the comment area where you wish to place a photo.
Could the clear bubbles be glycol?
Also, the picture below shows how much water leaked from the rear of the trailer early this morning after the rains but when the sky is quite clear. Any help is appreciated.
The pictures uploaded upside down! My apologies.
I can’t think of anything mechanical that would leak from behind the passenger side wheel except the Alde convectors. Check under the bed/bench inside.
If I remember, there is a molded plastic, trim on the rear that can collect water. How about a picture of the rear?
https://tab-rv.vanillacommunity.com/discussion/14526/floor-repair-due-to-rear-leak-in-2018-320s#latest
https://tab-rv.vanillacommunity.com/discussion/8446/leak
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
https://tab-rv.vanillacommunity.com/discussion/7120/2018-t-b320s-water-dripping-from-under-rear-trim-and-undercarriage-water-barrier#latest
https://tab-rv.vanillacommunity.com/discussion/6393/
As @Horigan has suggested, always use a urethane or polyurethane based caulk/sealant and NOT silicone on the exterior of the camper. nüCamp uses Geocel 2300 MHRV, a marine type urethane or polyurethane based caulk/sealant, but I am not sure what they use under the wheel wells, but maybe it is the same, only in a black color. A similar product, which may be more readily available through most RV stores (e.g., Camping World) is Geocel ProFlex RV Sealant. I believe you can get it in different colors (e.g., white, black, clear. My notes indicate that the "clear" version product number is GC28800, but double-check that if you are looking for a clear sealant.
If you search this forum (using the search box at the top of each page) for "sealant," "caulking," "seal maintenance," or similar words, you will likely likely find plenty of discussions on this topic.
