We are camping this weekend and cannot get the Alde to heat our water. We have sure power so we have chosen both electric and propane but the water will not heat. Does the temperature setting need to be warmer than the actual air temperature in the camper? Currently it is 81 degrees inside. Do we need to push the Alde up past that? I think it only goes up to 86 if I am not mistaken.
2022 T@B 320 CS-S Boondock
2018 Nissan Frontier 4x4
SW Ohio
0 ·
SW Ohio
Here's another video:
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
So hot water in summer requires heat.
Discussed last fall with Nucamp and with Alde, no resolution. Alde suggested we try replacing controller on this new camper at our own expense.
How many others have this issue? We need to document if there's a systemic programming issue on a run of Aldes.
Ours was manufactured Dec 2020 per nameplate.
When I turned on the Alde the water temp was 79 degrees (glycol 95 degrees) and after about 20 minutes, it went up to 129 degrees (glycol 160 degrees). The water at the sink is certainly warm but not as hot our inside tap water in the house. Would this be considered normal?
One other question, I took the panel off above the toilet to check the glycol level in the reservoir. It appears to be about half full. I haven't found a full line on the reservoir, so how do I know if it is full? Thanks everyone!
SW Ohio
The TaB is not going to give you water any hotter than 130-140F. The water tank is always going to be cooler than the glycol temp, and you loose some heat on the water pipe run from the heater to the galley sink. I find 120-130F water is hot enough for washing up whilst camping. If you want hotter water for a rinse, heat some water In a kettle on the stove. That is what I do.
SW Ohio
Lastly, some valves may actually be backwards and require the opposite adjustment to increase the temp or the valve may simply be defective. Try the above suggestions first.
SW Ohio
uCamp was fun as usual. They really go all out for their attendees.
