I have had two 320's with the Alde heaters, I know New Camp builds the wider 320 for Ultamate Campers without the Alde heating system whitch I wish I had bought. Does New Camp make the 400 without the Alde system? Just to much maitance with the Alde system for me. Art
2019 TaB 320 S Boondock Edge
0 ·
However, if something does go wrong with it, then it's not an easy DIY fix more often than not which makes it undesirable for some (including me to some degree). To answer your question though, I'm not aware of any T@Bs that don't use the Alde, but I'm not sure about their truck campers.
https://www.rvtravel.com/think-twice-alde-heating-system-1991/
Add in that people do have trouble getting service. When Alde was on the west coast, at least we had good customer service from them, even access to parts, by calling them directly. When Truma bought them, a lot of that went out the window. Mobile RV techs often aren’t familiar with the product and certainly don’t carry spares for them the way they do with your typical furnace. Dealerships are barely better educated, as a number of people here have experienced.
Then the corrosion & Rhomar vs Century saga began, and honestly for me, that was the point where I started considering the Alde a liability versus an asset. But had nuCamp & Alde handled it the way Airstream did, I might have stayed a fan. Instead, only the newest rigs were provided with the very pricy new fluid exchange for free, and the rest of us got, in effect, *shrug* “well, maybe you should change over, but we aren’t really saying you have to, and oh yeah, any damage that occurs from our bad choice of transfer fluid is your problem.” Not the way to take responsibility for your mistake on a very expensive appliance, and not the way to make your customers happy or loyal.
Meanwhile we have multiple dealers who can’t be bothered to do that changeover correctly, failing to thoroughly rinse out the Century fluid. And it’s a process that only the most DIY savvy among us can handle ourselves because of the pump required to be sure all the old fluid is removed.
It’s a great system when it works, and if the flush & fill process were every five years as in Europe, and the corrosion issue hadn’t happened, I’d probably love it. But as it stands? No way will I ever buy another rig with one.
That being said the Alde would not be my first choice for an RV system for several reasons. First off is the glycol replacement every 2 years. Second is that it does take a long long time to heat up the trailer in very cold temps. I know for most people who live in normal climates that is not an issue but for us it is. Another reason is that there is more that can go wrong with it. The unit itself can have an issue (as all units can) but then add the fact it is a radiant system that has multiple locations that can spring a leak and or have corrosion (force air systems don't have this possibility).
I honestly wish NuCamp would get rid of the Alde and use the Truma Combi unit instead. I have a Truma Vario heater in my truck topper/camper and it is wonderful. Is it louder? Yes it is but much quieter than the normal forced air systems. And mine is mounted out in the open. I can only imagine how quiet it would be mounted in a cabinet. Also I do like the digital control panel it uses. I think the Truma units would heat the trailer much much faster, are less complicated to operate, have less opportunity for failure and require less maintenance. If NuCamp could make that change along with switching to Arctic Turn windows and doors the trailer would be better off.
Find me another furnace hot water heater and furnace that I can at night and still hear the coyotes and elk. Good luck. Instead, they would be drown out by the sound of forced air.
Also, find me another furnace that uses LP and battery so efficiently and is so perfect for boondocking.
One FB comment correctly noted the article was just "One Owners Opinion" . . .
I was also disappointed that Dave S. even shared the letter, as Dave S. has zero real-world experience with the Alde System.
Several comments here note a few of the real-world issues with an Alde System and Yes it is not perfect.
And while a Truma Combo Plus system (forced-air {reported to be quieter than standard RV furnaces} and tank-less hot water) might be an acceptable option . . . for me the Alde is amazing and well worth the learning curve and maintenance.**
In general I question 'manufacturer' guidelines on fluid changes. As my Consumer Product Industry Manufacturing Experience has dozens of examples of Marketing, Sales, or Distributor Senior Management 'reading' Engineering Department data as they feel is needed to promote revenue growth.
For example, when the Big-3 shifted to 100 Thousand Mile major tune-ups all of a sudden oil changes dropped to 5,000 - 7,500 miles from 10,000 or 15,000 the years before. All while the motor oil quality had improved, standard oil filters had improved, and engine build quality improved - - - - that has far more to do with Dealership Service Revenue than actual engine performance. Yes, the engineering department reported those intervals but as very ideal or very hash use . . . not their 'typical' owner experience.
So those other department VP's could justify requiring the computer to beep-beep-beep oil change is overdue
Adventures: 58 Nights: 405 Towing Miles 50,180
2013 Tundra TRD 5.7L
Massachusetts
Oil is less efficient due to relatively lower specific heat and higher viscosity. It also carries more risks (it's a fuel source in a fire; much messier to clean up a leak; higher environmental impact for disposal)
2022 T@b 320 S / 2021 Subaru Outback
2020 Tacoma TRD Off-Road
