Question:
Has anyone else experienced a Water
Damage Sagging Floor and not undertaken a major & full floor
replacement?
That is you are living with it or completed some level
of repair.
Background:
My 2018 composite structure floor is
sagging on both sides of the floor frame cross-bar.
Communication
with nuCamp service has confirmed:
a) This is a known failure mode when water intrusion occurs.
While nothing rots water can/does enter the composite structure at the cross-bar seam.
The water soaks into the foam, adds weight, causing the floor foam to sink.
b) This is not considered a safety or trailer usage risk.
For my trailer the floor section forward of the cross-bar has sagged/sunk enough that the bottom of the composite structure is now resting on the torsion axle housing.
Bottom Side View
Reference Cross-section
My Repair(?) Plan:
I intend to cut out the damaged vinyl floor covering & pad.
Install some peel & stick vinyl.
Place a small rug over the area.
and Yes, fully disclose if/when the trailer is placed on sale }
Thoughts ?
Additional Background can be found in this forum post:
'18
320 S,
pitched axle, 3020HE; PNW based
Adventures: 58 Nights: 405 Towing Miles 50,180
2020 Tacoma TRD Off-Road
Why are owners tasked with repairing it?
If ever there was a case for the manufacturer to provide repair service, this is it.
There is a clear history of failed attempts to improve the design, including this one.
Talk about a smoking gun!
I fully agree that the 2018 floor design and maybe the build quality 'for water intrusion sealing' was less than ideal . . . I'm not comfortable saying this is fully a nüCamp failure.
Product design evolves as production and/or usage defects become known and nüCamp has been working to improve the floor structure design for many years.
Also, my rig is past the warranty period. Yes, a longer warranty should be provided from a customer viewpoint but nüCamp is still ahead of most RV builders on duration and they frequently make repairs outside of the warranty.
Add in my rig usage. Over 35K towing miles, several hundred on gravel or two-track dirt roads, and winter weather miles across states than use salt for road ice control. While these are reasonable usage, I expect they are also well beyond the typical usage parameters used during the trailer design/specification process.
Finally. nüCamp responded quickly to my initial** request for information/help/suggestions regarding my floor sagging situation. They were open about it being a known failure mode for this composite floor design and did provide helpful comments on the issue.
My original message to nüCamp suggested a repair plan of cutting and pulling up the vinyl to dry out the sub-floor and vinyl, then gluing the original vinyl back down. nüCamp considered this a reasonable plan.
Note: At that time the floor bottom resting on the axle was not known.
Earlier in this tread, My plan was to remove the vinyl and use peel&stick replacement vinyl.
Today while inspecting and what-if'ing the floor I decided to return to the original plan to reattach the factory vinyl to the sub-floor. This will look better and will be smoother. And if it does not "take" can be undone. Of course the wheel well bad seal needs to be redone and I'm not done searching for other possible water intrusion locations. Plus this ignores the floor resting on the axle . . .
My vinyl flooring is starting to bubble again in several areas and I’ll be doing my initial needle and glue fix for these areas once again. More time, money and sweat. I feel like for every good memory I get out of this camper it’s quickly replaced with another repair I have to undertake. Luckily this repair isn’t anything @MuttonChops is dealing with but they all add up. Nothing will change unless the consumer stops buying the product I guess.
This Tab is the 5th RV I’ve owned by 5 different manufacturers starting with a vintage motorhome. Two were purchased brand new, three used. ALL were time and money drains. I’ve heard the same from others. Sadly, it’s just the nature of the beast; even the best built RV is a rolling earthquake routinely or constantly exposed to the elements, things are going to break or fail or just need a lot of regular maintenance. And most RVs aren’t all that well constructed.
Generally speaking, the Tab is better built than at least 90% of what’s out there, but stuff like this, where an apparently poor design choice was made and we’re stuck with the results, is incredibly frustrating.
Edit to add: The more I think about it, we’re reaching a point with these trailers that every model year in the last several has a different potentially significant flaw. You shouldn’t have to wonder if you bought just the right model year or if some major design issue is going to crop up in yours down the road. Maintenance failures and general wear and tear repairs are a very different thing in my mind than these poor material or design or appliance choices on the part of the manufacturer.
Lately I've been looking at Imperial Outdoors trailers and have honestly not seen a trailer built and insulated so well. The floor, wall and roof systems are really incredible. There are some great videos on the construction of the trailer. You certainly pay for what you get and they are large heavy off road capable trailers so certainly a different market. But the X-22 or X-145 would be on my list if I could swing it.
did the same when operating a 28' Recreational Tug and ended up owning that boat for 23-years
it had several DIY dry-rot wall repairs but a solid heavy 1960's fiberglass hull - - as in the fiberglass
should be as thick as if wood was used. A great boat but life forced me away from the coast . . . .
My current short list of replacement travel trailers are:
+ Tab 400 . . . . it has the Alde System, and it has a Black Tank
(I dislike the current 320S Cassette Toilet and Air8 A/C)
+ Helio O2 . . . . positive construction reviews, but limited Black Tank and other features.
+ Rove LIte 14FL . . . new improved construction but a brand not known for build quality.
earlier Falcon model was on my short-list before purchasing the 320S
and the Falcon was a real build material/quality failure.
The Helio and Rove also lack supportive owners forums like the TaB Family
- - - they have small facebook owner pages and imho facebook is not as useful as a classical forum.
As for Imperial Outdoors - - - I really don't need that level of off-road performance as 75% of my camping has been in FED/State/Private RV Parks. And for the trailer size I would be interested in . . . a Dry Flush Toilet is not for me.
My concern with the dry-flush is the waste getting into landfills or back-country ditches,
not being 'waste processed' and in a sealed bag that will not breakdown for years . . . just seems
to be a pending public health issue . . .
I spent a fraction of this time fixing anything dealing with tent camping. I’m a relative newbie to RV’ing. Only had a popup camper before this. I’m just glad I’m relatively handy, otherwise I honestly would’ve sold our 400 shortly after getting it. Just mostly small issues (and a couple major) but if I weren’t handy they would’ve easily overwhelmed me.
trailers are being compared against utter garbage (I’m looking at you Forest River) so it’s not a huge effort to beat the F students. We’re just used to these things failing us.
With vinyl pulled up the old adhesive patterns suggest nuCamp used wide spaced beads of adhesive instead of a full smooth cover as would be used for a residential floor - - - which could be part of the overall 'floor bumps' or bubbles so many owners report.
. . . expect re-installing the air-flow shield will be a real pain . . . .
-Denise
. . B . . I do not know what the Brittle/Black/Man-made Material is.
. . C . . I did not 'raise' the sunken floor area. I've just dried-out and re-bonded the upper vinyl
The tank bottoms are resting on the axle due to the sagging.
The tank tops are normally in contact with the floor bottom and still are.
. . D . . I decided not to make an issue of this with nuCamp as my rig only has a
one-year structural warranty period.
. . E . . If my leak source is the wheel well area it is due to the factory sealing
material failing after extended usage. So any additional 'sealing' you can
provide won't hurt - - - belt and suspenders.
