We bought a used 2007T@B thus July and the previous owner rewired it, anybody have a wiring diagram on the wiring as it come into the trailer. I have the lights etc, working but there is a drain on the battery and just setting it discharges in 48 hours. Anyone have any suggestions? Doug
0 ·
What, if anything, is turned on in the trailer during the 48 hours?
Also, if you have a "3-way" refrigerator (i.e., battery, 120V AC, propane), are you trying to run it on the 12V battery? Usage of the battery is only for purposes of "maintaining" the refrigerator temp, usually while you are towing. However, it does a poor job of maintaining the temperature. If the refrigerator is relying on the battery (unless it has high capacity, such as with a lithium battery) while the trailer is parked, that will definitely quickly run down the battery.
The attached image file has the Dutchman Diagram; diagram drawn in 2005 and was found in a 2008 Owners Manual
(I do not have Owners manual or recall were I found this image on the web)
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
